fitting oil temp guage to frst
Old Sep 9, 2008 | 03:15 PM
kieran265's Avatar
kieran265
Default fitting oil temp guage to frst
hi i have a oil temp guage with no instructions on how to fit it, i no about power just were to connect to get temp
thanks kieran
Old Sep 9, 2008 | 04:10 PM
rst230bhp's Avatar
rst230bhp
Hi mate
You can get a and adapter which replaces the sump plug with a sender and that connects to the back of the gauge, you can get the adapter from demon tweeks, burton etc.
Old Sep 9, 2008 | 05:54 PM
kieran265's Avatar
kieran265
i gave a few different connectors with it could 1 of these b it?
if not any ideas were they go
thanks kieran
Old Sep 10, 2008 | 01:00 AM
rst230bhp's Avatar
rst230bhp
Hi Kieron
This is what you need, the adapter replaces the sump bolt and the tempreature sender screw into it, then all you got to do is connect the gauge wire to the end of the sender.
http://www.demon-tweeks.co.uk/resour...O_SUMPPLUG.jpg
http://www.demon-tweeks.co.uk/resour...ITT300138N.jpg
The above links are just examples and may not be the correct ones for your car.
Hope that helps
Amit
manuel boeckx
13
Oct 3, 2015 02:29 PM
Kop2381
Aug 23, 2015 01:17 AM
mrmann
Aug 20, 2015 11:24 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
COSWORLD
Aug 14, 2015 07:40 AM
