1.8 Zetec - Swap For CVH Turbo?
Old Sep 9, 2008 | 09:29 AM
Cozziekid's Avatar
Cozziekid
Default 1.8 Zetec - Swap For CVH Turbo?
Mk6 Escort, is it worth swapping a Zetec for a CVH turbo engine?
To turbo my 1.8 properly will cost quite a bit.
Just wanting a quick easy way of getting turbo power for little money.
What bits would i need for the conversion?
Thanks for any help
Old Sep 9, 2008 | 03:36 PM
spookie's Avatar
spookie
Talking
why not turbo your zetec engine. just visit;
http://www.zetec-turbo.co.uk/
easy.
Old Sep 9, 2008 | 03:47 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Because the compression ratio and management map could stop you from running a decent amount of boost to make the effort worth while.
Old Sep 9, 2008 | 03:49 PM
dunketh's Avatar
dunketh
Chief Iron Oxide Farmer.
Have you considered uprating the zetec to 130 spec, mondy cams and all that guff or are you set on turbo power?
Old Sep 9, 2008 | 03:55 PM
craigos's Avatar
craigos
no
Old Sep 9, 2008 | 08:50 PM
Cozziekid's Avatar
Cozziekid
easy.
Because i dont trust decompression plates, if i wanted to do the Zetec i would do it properly with forged pistons etc.
Dunketh: Im not set on turbo power mate, but i do think my 1.8 is getting a bit gutless. Just thought it would be a quick easy & cheap way of getting turbo power for a change.
Matt Baxter
Sep 16, 2015 08:30 PM
Dubs44
Aug 21, 2015 02:42 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
gingerturbo
Aug 11, 2015 09:44 PM
