Which To Use???
Old Sep 8, 2008 | 07:11 PM
pauldonachyrs's Avatar
pauldonachyrs
Default Which To Use???
Which Uprated Fuel Pump Should I Use On My Small Turbo Model Escort Cosworth Im Going For Stage 2 Been Told Thats About How Far You Can Go Without Spending Thousands Pounds
Help Needed New To The Escort Cosworth Small Turbo Tuning Side Of Things Cheers Lads..
Paul
Old Sep 8, 2008 | 07:44 PM
ECOS95's Avatar
ECOS95
Walbro 255ltr would do that. Ł80 on ebay.
Old Sep 9, 2008 | 10:52 AM
auralisRS's Avatar
auralisRS
Hi
What is stage two then? I have ST, with Collins Chip etc. I use standard pump. Seems OK.
Thanks Mark.
Old Sep 9, 2008 | 11:28 AM
ECOS95's Avatar
ECOS95
Stage 2 is around 300 BHP, Stage 1 being 275 / 280 BHP. I'm sure you'd need a Hybrid T28 to get close to 300 BHP reliably.
The standard pump comes from a 1.6 Escort. For the sake of Ł80 I'd swap it if you've chipped it especially as they're getting on now.
Old Sep 9, 2008 | 11:56 AM
auralisRS's Avatar
auralisRS
I have the Hybrid T28 on mine, forgot to mention - from Turbo Technics. Goes well my car, holds boost well, but because it doesn't run lean, (like lacking fuel), I have never changed the pump. Makes you wonder if it would make any difference.
Old Sep 9, 2008 | 12:12 PM
carlo's Avatar
carlo
Got any pics of your car paul i had a small turbo escort a few years back with the ggr 305 conversion it ws piss poor got andrew gallacher to convert it to big turbo
Old Sep 9, 2008 | 01:07 PM
pauldonachyrs
get pics up on better day its pissing down up here lol
Old Sep 9, 2008 | 01:08 PM
pauldonachyrs
dont people use the bosch 044 one..
is the bt ones same as the st just use the same pump...
where is best place and cheapest place to get my hands on one...
Old Sep 9, 2008 | 01:09 PM
carlo's Avatar
carlo
Same here mate hence why i had the s1 up for sale also i wont drive it in the wet so its all tucked up..I had the ggr pump in mine
Old Sep 9, 2008 | 01:10 PM
carlo's Avatar
carlo
Contact tf rallyesport or paul @ north yorks
Old Sep 9, 2008 | 03:45 PM
ECOS95's Avatar
ECOS95
Bosch 023 is an internal, the 044 I'm sure is external. The pumps are the same for BT & ST.
Old Sep 9, 2008 | 04:58 PM
JHS's Avatar
JHS
Thats right
Old Sep 9, 2008 | 05:02 PM
pauldonachyrs
so go for a bosch 023
Old Sep 9, 2008 | 05:05 PM
pauldonachyrs
can you send me contact numbers mate
Old Sep 9, 2008 | 06:11 PM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
i have a second hand 023 with fitting kit going if your wanting one i have a one off sysem now...
Old Sep 9, 2008 | 06:36 PM
pauldonachyrs
how much matey???
this the one for the stage 2 chip
internal is it
Old Sep 9, 2008 | 08:16 PM
redrsmk5's Avatar
redrsmk5
i run a 003 which is good for 400bhp but if you can get an 023 even better
Old Sep 9, 2008 | 09:31 PM
Lighty's Avatar
Lighty
I have just put a 023 pump in mine. With a chip from MSD -31 it's like a new car now. Can't wait for the chip to be finished so i can run the big turbo...
Old Sep 9, 2008 | 10:17 PM
adamski frst
Originally Posted by pauldonachyrs
how much matey???
internal is it
i have 2 003's which are rated to about 400hp the 023 is rated to about 450- 500hp like i said i have 2 003's and one 023 all are for our cars and internal and i have the fitting kit which i can sell with it too that you need to run...
As said was fine on mine i just run a one off setup now i use just external ones so these are no use to me anymore pm your way
Old Sep 10, 2008 | 11:30 AM
mikedaf2's Avatar
mikedaf2
ive put an 044 inside the tank, bit of a squeeze but just goes in. I found this to be a stronger pump that the 023 that was in there but then i dont know how old it was.
Old Sep 10, 2008 | 02:45 PM
pauldonachyrs
think il goe wee the one you have mate as im no gonna run crazy horse power any way...
Old Sep 10, 2008 | 05:42 PM
adamski frst
well if you want it just give me a shout and we can sort out which one you want and pay me and i'll get it over too you
