2wd Cosworth Brake system Problem
Hello everybody,i have in my cossie 4pistons WMS calipers with bells and 310mm rotors,and i have inside the car switch for ABS on - off ,when i select the switch off ABS, then the car stops with rear calipers i mean the pressure is not enought for front calipers i think,
with result the car is not braking well,and the rear brake is too strong ,so the rear part it turns, so what can i do for that?anyone knows? any help appreciated.
* i have made gasify in whole brake lines a lot of times!!
Thanks a lot.
Thanks a lot.
the pistons are 44.5mm,but maybe has it spoils the round black part i don't know how is called in English,i say that because the pedal has the sense like sponge,as it loses air.(sorry for my bad english)
jason_nike
Aug 18, 2019 10:53 AM
Aug 14, 2015 07:29 AM
