S1 Ecu On To A S2
Yup as above it will be fine although the knock sensor will not work (if it has one? early S2's didnt but its a G plate so it should!).
You dont have to swap the fuelling ECU, i'm runing a S1 ECU wiht my S2 FUelling ECU no probs, and my brothers S1 has a 90spec Hearts and Diamonds ECU with his original S1 fueling ecu.
But a S1 fuelling ecu is better as it has no rev limiter
If you do use one you'll need to rewire your TPS or you will have no full throttle enrichment, or fuel cut on closed throttle. You'll need to run the earth from the TPS to PIN 6 of the fuelling ECU (iirc).
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
Sep 14, 2015 09:04 PM
