What plugs...
Nov 8, 2004 | 06:39 PM
What plugs...
What spark plugs do people recomend i use in my S2 Turbo?
1600 CVH, low compression, runnin aprox 18psi
Ta
Nov 9, 2004 | 09:39 AM
Champion QC57C or QC59C with 0.6mm gap. 57 will cope better with heat, so if 59 doesn't work try 57.
Nov 10, 2004 | 01:39 PM
I use N.G.Ks
Nov 10, 2004 | 02:59 PM
NGK 9's in mine!
The champion QC59C's are ok or the NGK BCR8ES's. Depends on how much u wana spend and whether you want the best!
Nov 10, 2004 | 07:37 PM
Nov 10, 2004 | 08:50 PM
I run 071's with a 1mm gap and find them lovely.
Nov 10, 2004 | 11:21 PM
I'm running std escort cossie plugs in mine. did use to have QC57C but was recommended to use the cossie ones
Nov 11, 2004 | 06:45 AM
ngk 9's in mine! 200bhp!
poolielad
Ford Focus RS
Mar 5, 2010 08:30 PM
S2_RST_DK
Jul 18, 2008 04:08 PM
