Any vauxhall techs about? Chip maybe?
Old Sep 5, 2008 | 10:00 PM
RichieST's Avatar
RichieST
Default Any vauxhall techs about? Chip maybe?
Hi all
My sister lives abroad and has got a 52 reg corsa, which she's having some problems with. This is her email!
I've been having on/off probs with my car whereby it won't start. I get a couple of lights come on on the dash board but they don't all light up, the mile counter thingy doesn't come on and when you have the key in the ignition and the driver's door open I don't get the usual beeping noise you would normally get. The car will turn over but not normally actually start and if it does start it conks out again straight away. I've always got it going again by fiddling with fuses and once it's running it's fine.
John has taken it to see a mechanic he has at work and he reckons it's a problem with the immobiliser. Namely that when I get out the car I double lock it with the key fob....press the button once to lock the doors and then again to activate the immobiliser. This lad reckons the prob might be caused because the battery in my key fob is too weak (it does need changing) to deactivate the immobiliser. The doors get unlocked but the immobiliser still works. He reckons I must then fiddle with the right fuse to deactivate it in the engine and away I go.
I always thought it was caused by bombing it down the motorway at 85mph to work and frying something under the bonnet so next time I jump in it, it says I don't blinkin' well think so missy. It was only because it happended to John when he took it to work yesterday (about 2 miles away from home, through slow town traffic) that I've come to think it's not my fault after all!
Do you think the key fob/immobiser problem is feasible or doesn't it sound likely to you? It's only an occasional problem....99% of the time it starts absolutely fine. It's going for a service on Monday so we'd like some idea so we can mention it to the non-English speaking(?!) people when we book it in.
Anyone got any ideas? I thought perhaps dodgy earth or maybe a relay?
Thanks
Rich
Old Sep 5, 2008 | 10:05 PM
mechanic28's Avatar
mechanic28
two possiably fixes come to mind!there is a ecu update for immobiliser communication problems !not sure if the garage she is taking it too will have a tech 2 etc?the other one that wil cause this is the wiring harness plug behind the instruments becomes loose!need to remove the instruments put some foam behind the connector to make it more snug fit!
Old Sep 5, 2008 | 10:06 PM
Physio's Avatar
Physio
Ok firstly, your sister sounds funny
Secondly, if the car works when she messes about with the fuses then it's more than likely to be a dodgy connection in the fuse box or something imo.
Thirdly, is she fit? Pic's?
RichieST's Avatar
RichieST
ok cheers mate! So if the plugs come loose behind the clocks, will that make it not start?
Old Sep 5, 2008 | 10:08 PM
RichieST's Avatar
RichieST
For starters aj, she's about 5'10, so WAY out of your league
I did suggest a fuse box problem to her, so will see what happens
Old Sep 5, 2008 | 10:10 PM
Physio's Avatar
Physio
Cunt
Old Sep 5, 2008 | 10:11 PM
mechanic28's Avatar
mechanic28
yes mate!its part of the immo!plus that causes some of the lights not to come on!
Old Sep 5, 2008 | 10:41 PM
Benni's Avatar
Benni
Ban[B][/B]ned
Afpmslllllll!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 5, 2008 | 11:18 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Glad you knew Mechanic28, cause I sure as hell didnt, FAR too modern for me
Old Sep 5, 2008 | 11:21 PM
purple_fiesta's Avatar
purple_fiesta
No longer a ford owner ..
Yeh ive had a couple like that, like mechanic 28 says, use abit of number plate foam behind the plug and im sure you have to cable tie some wiring back
Old Sep 6, 2008 | 12:05 AM
mechanic28's Avatar
mechanic28
u can use a modified wire loom but i have never been able to find the part number for it!woo-hoo i have been usefu on here the once instead of talking bollocks!
Old Sep 6, 2008 | 12:11 AM
b_kennedy's Avatar
b_kennedy
dont remove the clocks with the ignition on! ABS light will activate and will not go off until you pay a vauxhall techy :-(
Old Sep 6, 2008 | 01:49 AM
ECU Monitor Enthusiast
PMSL
Old Sep 6, 2008 | 05:43 AM
rst in breaking's Avatar
rst in breaking
you never answered matey? pmsl
Old Sep 6, 2008 | 08:12 AM
RichieST's Avatar
RichieST
Married to a seargent major in the army with bigger biceps than all of us put together on here, plus a baby on the way! So i think that puts her firmly 'off the menu'
Thanks all for the replies, will let her know
Old Sep 6, 2008 | 08:16 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
no idea on the solution but your sisters email made me laugh.
Old Sep 6, 2008 | 11:55 AM
RichieST's Avatar
RichieST
Just had this email back from her -
Thank you for your help! I thought it sounds more like a loose connection problem and the dash clocks sounds likely....it might explain why, when I'm driving, they sometimes give up and all read zero even when I'm bombing down the motorway!! The engine still runs fine I just don't know how fast I'm going etc! If this is the case, would it prevent me being able to start the car though?
Like I say, it's going for its major service on Monday so I'm hoping they might plug it into something that might pick something up!! Taking my dashboard apart doesn't sound like fun so I might wait and see what they say on Monday (I'm going to mention the problem to them) and if they come up with something then that's fine but If not then I might have a tinker! We're selling it soon anyway so I don't want to do anything too extreme, I just need to know it'll start at least to allow some poor person who buys it to get it off the driveway and a few miles away before it konks out!!!
Deffo sounds like the dash clocks then!!!
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
tankybaby66
Feb 6, 2016 02:24 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
RSmark84
Sep 13, 2015 01:29 PM
