2x 4x4 cosworth heads
1st head measures 138.8mm £500
2nd head measures 138.55mm £400 and has some small det marks which will clean up no problem
If Interested Please Phone: 07599705340
more engine info please.
details of what rebuild was and from who.
pistons
bore
crank grind
bearings
mileage done
head gasket
head work?
compression
and where are you based?
steve
pistons
bore
crank grind
bearings
mileage done
head gasket
head work?
compression
steve
right engine has been removed today its is just a standard 4x4 engine with group A head gasket standard crank, rods and pistons, the engine even ran standard L8 ecu with standard boost, it is a perfect runner no noise or oil burning
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
