when fitting plenum spacer
Old Sep 2, 2008 | 05:33 PM
proboscus's Avatar
proboscus
Default when fitting plenum spacer
im just starting to fit a plenum spacer to my sapph.the fuel rail has had to be removed to remove the cover.will the fuel rail fit ok when the spacer is back on seeing as it bolts to the plenum cover and when the spacer is fitted it will sit 12mm further away from the injectors.
Old Sep 3, 2008 | 08:06 PM
Simmo's Avatar
Simmo
It's only the 15mm spacers I belive which are a direct fit, albeit with the rail bolted to the other side of the lugs. The 10mm and 12mm ones need the 2 lugs filed/cut down so the injectors fit at the correct angle... easy job!!!
Oct 9, 2015 07:38 PM
Cosnada
Aug 27, 2015 09:15 AM
Aug 20, 2015 09:21 PM
markk
18
Aug 17, 2015 05:19 AM
Aug 14, 2015 07:29 AM
