hpw to adjust thefuel on a s2 mfi
Old Aug 30, 2008 | 04:03 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default hpw to adjust thefuel on a s2 mfi
as above mine is runnin rich making it misfire when, how can i tweek it so less fuel is enterin the engine
Old Aug 30, 2008 | 04:35 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Here is a step-by-step guide.
1. Take it to a tuner.
Old Aug 30, 2008 | 06:05 PM
Karlos G's Avatar
Karlos G
Balls Deep!
How do you know it running rich? Do you have a wideband lambda and a AFR meter?
I know why dont you just turn the boost up to lean it out a bit?!
No.... only fucking about mate you cant do it yourself it has to be done by a tuner on the RR or you risk melting your engine! Best to be safe not sorry!
Old Aug 30, 2008 | 06:20 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
well my s2 is at harvey gibbs now any way
Old Aug 31, 2008 | 10:39 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Didn't you just have it set up???
Old Aug 31, 2008 | 11:18 AM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
yea had it set up at jamsport but it started to misfire, so i took it to harvey. gettin pissed off with it now
Old Aug 31, 2008 | 11:20 AM
kevnoize's Avatar
kevnoize
RsTurbo crewe ina corna.
doe's anybody no where there's any tuners in manchester????
yatta
May 21, 2016 10:31 PM
steve.rst
Mar 15, 2016 08:01 AM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
stevierob
Sep 7, 2015 07:09 PM
