Set of Door rubbing strips / 4x4 Sapph Inlet Manifold and more
Set of 6 Sapphire rubbing strips for doors and wing all straight, just needs the tape cleaned off the back and new double sided tape put on
£60
4x4 Inlet manifold
£40
2wd complete manifold with trousers £40
Polished bonnet stay £10
2wd head comes with all caps e.t.c, just needs cams and 4 valves that got dinked, measures 138.6 £225
AP clutch done less than 2K, its a 6 Plate, but comes with standard ford cover, was bought from Pete last year for Sell £125
2wd rear axle, just needs disks and calipers it is fully polibushed and also comes with a 4x4 anti roll bar (also poly bushed), driveshafts were rebuilt last year and the axle painted, there is light surface rust on it. comes with good 7.5 Inch Diff and is ready to fit £225
2ws front hubs, anti roll bat, tcas and crossmember with steering rack, or complete ready to go, has polybushes £75.00
have got some coilovers but they have also got surface rust, once i have cleaned them up and freed the adjusters these will also be for sale
2wd crank pulley £50
Magnacor 8.5mm red leads used but good £40.00
Set of fans £25
Sun roof motor, coweling and switch £30
Let me know as its all going on EBAY tomorrow if no one is intrested
THANKS
Keeping stack dash now, for those who asked before Sorry
£60
4x4 Inlet manifold
£40
Set of fans £25
THANKS
Anutternutter
Aug 21, 2015 06:07 PM
track.focus'd
Aug 12, 2015 05:53 PM
