cossie fusebox
Old Aug 29, 2008 | 07:28 PM
biggiejody's Avatar
biggiejody
Default cossie fusebox
has anyone got or can get a pic of a 90 2wd saph fusebox complete with fuses? as the lid for mine aint off a cossie and it needs fuses all over the place and the fuses that are in aint the right ones.
and worse case secenio does anyone now how much a complete car loom would cost?
thanks lads and lasses
Old Aug 30, 2008 | 12:33 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you can pull the box from the car without the need to unbolt it by just uncliping it from the fuse box istelf, the board is seperate
then just figure out which wires go where by using a wiring diagram
alternativly, get someone to post up the pics of the cover and the fuse positions and look there
much less hassle than pulling the box out i assure you
155lee
Sep 6, 2016 11:10 AM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
