series 1 ecu on series 2
Old Aug 29, 2008 | 04:11 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default series 1 ecu on series 2
will this make it misfire my series 2 is misfiring and took it to harvey gibbs he said i have the wrong ecu on it
Old Aug 29, 2008 | 04:20 PM
cozmeister's Avatar
cozmeister
More boost Igor!
He's probably right then
Old Aug 29, 2008 | 04:22 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i got the car with the s1 ecu on it, what is the differnce between the s2 ecu ans s1
Old Aug 29, 2008 | 04:31 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
s1 ecu has not got a knock sensor which can play up if you have a high lift cam or a bit of vibration i ran a s1 ecu for years on my s2 made 240 bhp no problems what so ever
Old Aug 29, 2008 | 04:32 PM
markyrst's Avatar
markyrst
s1 ecu will only work on early s2 models without a knock sensor. ive got a s1 ecu in my 87 s2
Old Aug 29, 2008 | 04:37 PM
G2RSR's Avatar
G2RSR
Bodybuilding
no mate they work on cars with a knock sensor its only the ecu that needs the knock sensor mine was on a 90 spec rs turbo
Old Aug 29, 2008 | 04:41 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
just because my rs is misfiring like a twat when on parkway it is fine,harvey said it is the wrong ecu, my engine has a knocksensor but if the ecu has no knock sensor will it misfire
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
AJC
Oct 8, 2015 11:09 AM
griffo69
Oct 4, 2015 11:58 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
