Clutch problems....
Old Aug 28, 2008 | 03:09 PM
sheps's Avatar
sheps
Default Clutch problems....
Will the problems never end with the car .
Last couple of mornings, go to start the cossie and the first press of the clutch has been really stiff. 2nd press is ok. It only happens first thing in the morning.
Do the same yesterday morning, and same as usual, stiff. So push down with some large left leg muscles and "click click" then pedal drops to the floor with ease.
Now, there is no real resistance on the pedal,a toddler could push it down with his little finger and it sits where it should do, but i can engage all gears without using the pedal at all (its quite odd to select reverse, and be able to get out and see the reverse lights)
But obviously, i can't go anywhere
Its a 2wd if thats any use?
Any ideas guys?
Cheers.
Old Aug 28, 2008 | 09:14 PM
cossieboyIOW's Avatar
cossieboyIOW
scrap it
Old Aug 28, 2008 | 09:16 PM
sheps's Avatar
sheps
Git, i buy it off you, and get a whole 500 trouble-ish free miles before it breaks !!
Old Aug 28, 2008 | 09:25 PM
cossieboyIOW
straight swap for an rst??
Old Aug 28, 2008 | 09:39 PM
sheps's Avatar
sheps
Har har har.
So anyone.....any ideas?
Old Aug 29, 2008 | 11:41 AM
martysmartie's Avatar
martysmartie
Sounds like a dodgy clutch cable perhaps or release bearing?
Old Aug 29, 2008 | 01:55 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Clutch rachet at best guess buddy !!
Pull the pedal up (towards you) & see if anything happens ??
jb
Old Aug 29, 2008 | 09:44 PM
sheps's Avatar
sheps
Ratchet is my first guess, pulling the pedal up does nothing
Someone mentioned to me about a collapsed clutch??
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
