ACT - what charge air temp range is safe?
Old Aug 27, 2008 | 11:08 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Default ACT - what charge air temp range is safe?
What is a safe temp for ACTs on a stage 1 saph (with standard 4x4 intercooler). Got a SECS monitor but don't really know how high is too high.
Cheers.
Old Aug 28, 2008 | 05:51 AM
KSA-Cossie's Avatar
KSA-Cossie
Mine never went above 58 degrees on the secs.
Old Aug 28, 2008 | 05:54 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Bad mojo occurs after about 60C. You ideally want to keep it as close to 40C as possible.
Old Aug 28, 2008 | 08:12 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Cheers. I've seen it go into the 50s occassionally but is usually around 35 - 40 when driving. Its good to have a rough idea of a top limit though. Thanks.
Old Aug 29, 2008 | 06:12 AM
KSA-Cossie's Avatar
KSA-Cossie
Mine sits in the 50's on a hot day in traffic but flat out is in the 30's.
Old Aug 29, 2008 | 12:45 PM
gaz4x4cos's Avatar
gaz4x4cos
were could i buy a secs monitor , is this the one that goes in the plage of the clock ? are they a diy fit ? what sort of price or any link would be great not been able to find .
cheers
gary .
Old Aug 29, 2008 | 01:55 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
cheers
gary .
http://www.randbmotorsport.co.uk/sho...?ProductID=294
I currently have a batch of five on order.
FYI ignore the readings you get from heat-soak in traffic, these are irrelevant. The 40°C (or less) to aim for, is only on wide-open throttle, you don't need to worry about any other circumstances .
Old Aug 29, 2008 | 03:43 PM
VEEDUBBED's Avatar
VEEDUBBED
What exactly happens if the ACT detects high temps?,does the car missfire?,stop dead?,cut out etc.
Old Aug 29, 2008 | 03:49 PM
cozmeister's Avatar
cozmeister
More boost Igor!
When the ECU detects a high inlet temp, it will retard the ignition...
Old Aug 29, 2008 | 05:37 PM
rapidcossie's Avatar
rapidcossie
you want your ACT's to be kept as cold as possible.
Cooler air = more bhp.
Once saw a cooler that kept ACT's at ambeint temps no mater what the boost
Front of the car had to be modded a little for it to fit tho
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
