Stage 3 Head Conversion?
Old Aug 23, 2008 | 08:22 PM
S1Luke's Avatar
S1Luke
Default Stage 3 Head Conversion?
Hi guys,
Currently one of my S1 engine's is running just under 200bhp with 18psi boost. It has a standard head and internals. I've been offered a stage 3 head. Can anyone tell me what power increase I could expect if I fit a stage 3 head? Also will there be any bad effects e.g increased lag? and will I need any remapping etc after fitting it, or is just a case of swapping the head and off you go?
Thanks very much in advance for your help.
S1Luke
Old Aug 23, 2008 | 08:46 PM
project rs's Avatar
project rs
stage 3 head of which company and you should need a re-tune if it does what it's supposed too as it should be shifting more air so might go lean
Old Aug 23, 2008 | 11:54 PM
Alex_86's Avatar
Alex_86
get a decent cam to it and lifters
then if your running mfi (ke-jet) get the ecu chipped, and a 5th inj would be good too
Indyrs
Dec 4, 2022 12:39 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
Chopshop85
Sep 18, 2015 06:13 AM
