Toad AI606 quick question
Old Aug 22, 2008 | 02:24 PM
BM08's Avatar
BM08
Default Toad AI606 quick question
Ok when the car has been disarmed/unlocked for a while, when you want to start it what do you do?
Only way ive found so far is turning the ignition on, then press the button, then turn the ignition back off and on again but surly theres an easier/quicker way?
On my old clifford all i had to do was turn the ignition on all the way, then press the button once and then it would start.
Old Aug 22, 2008 | 02:29 PM
All you have to do is turn the ignition to position 2(run) press ARM button and it will reset the immobilser, allowing the igntion lights to come back on and then to start.
If it does not do this I would check where he has taken the power feed(igntion from), on my C5T2, I have to re-arm dis-arm thing but it is on a vauxhall with no accesssory live from the ignition switch.
Old Aug 22, 2008 | 02:46 PM
BM08's Avatar
BM08
what i was doing is turning the ignition to position 3 not 2.
Ill try it later, cheers
Old Aug 22, 2008 | 03:24 PM
trev27's Avatar
trev27
I just press the disarm button and it works
Old Aug 22, 2008 | 03:27 PM
BM08's Avatar
BM08
Thats abit vague? at what point do you " press the disarm button"?
When the ignition is in position 2?
Old Aug 22, 2008 | 03:48 PM
xr4x4rs's Avatar
xr4x4rs
i just press teh disarm button if im going to the car and its just immobilsed
or if im in teh car igntion on, press the btton and then start the car
Old Aug 22, 2008 | 03:57 PM
kjc300's Avatar
kjc300
me too, just press the disarm button again, ign on/off wherever
Old Aug 22, 2008 | 03:58 PM
BM08's Avatar
BM08
cool cheers guys
Old Aug 22, 2008 | 04:08 PM
Jim Galbally's Avatar
Jim Galbally
i also normally just press the disarm/unlock button just before i try n start it, has the same effect as putting it on 2, pressing a button then starting
Old Aug 22, 2008 | 04:10 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Yep! Thats the way! Always works on mine!
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
