FAO Tabetha
Me Cossie Runs Atlast!!!!
Hi,
No not got final map yet as there is a THREE MONTH waiting list!!
I am down for a no notice cancellation though, as can just drive car and leave with dave all day, as only a 5 minute walk away.
I did get some PM's from various people but as said there are many problems at the mo.
I want to come over and see mr bumpy anyway, and interested in another bit you have for my dad, so will pop over next few days.
Car is stunning on "get you by map", fuel economy is absolutely unbeleivable, I would not beleive it if someone told me it would do this, I thought it was down to closed loop, until speaking to dave, it's not even enabled yet, he says they are pointless, if you don't have a cat, so long as mapped right, from his results I can only agree.
CO was 2.25%, and falling(as warming up) and was getting towards 1% no cat and perfect running, pulls from 800rpm top easy(laggy of course) but starts boost from 1400/1500.
It is such a joy having boost control related to TPS as well as the rpm, so much nicer and smoother utter joy as no surge to die down when you lift off like a std ecu, massively more driveable.
Only got part map done as TPS went tits up, so rather than pay cossie tax!!, I fitted a universal brand new one at Ł25, went to tps screen and aligned it(at daves) for perfection, so easy to use this system, even I can do it, even managed to get lappy working with ecu yesterday, so going to check the fan on off points, just using the one fan control at the mo but it has two, then just got to fit my clutch switch for full throttle gear shifts.
Upon looking at the spec this can run 12 different trigger patterns including motorbike ones(suzuki/yamaha/ducati), one is being put on daves old norton as it gets converted to fuel injection.
ps just got to place all the spaghetti of wires back now!!
And the one day im not at the garage you come over
Had to pop up norwich and get some clutches and thrust bearings.
Thats one hell of a long waiting list!
Long waiting list, if only you knew, he has had to stop leoni + kim in the office booking more than 3 months ahead, could fill three months worth in a few weeka without problem!!
Your pa said you were at college, then moaned about you leaving tools all over the place so he can't find them, ha ha!!, I shant tell you what he called you.
Are you there on friday, as will pop over if you are ?
Bloody pm's still up the shoot.
Will be there all day tomorrow! See you then.
When you thinking about coming over this week mate? Should hopefully be able to start it on friday if i get your module!!! Got lots of bits turning up tomorrow and thursday
Im not in thursday afternoon but all day tomorrow
Chris S
Jan 4, 2007 07:11 PM
Disabled Account
14
Oct 25, 2005 06:55 AM
Disabled Account
Jun 14, 2005 06:17 PM
