breaking cosworth....
i'm breaking my magenta saph cossie due to accident, i'm not selling engine, gearbox, prop, diff or ecu. alot of the body parts are damage just ask to see what i have, full cloth interior, brakes , part suspension, body kit, exterior door/wing trims, part stainless exhaust (no back box) all ok
some samco's and may sell my baileys breather system.
i have a 2wd and a 4wd exhaust manifold
escort cosworth crank pulley
escort cosworth power steering pump with backing plate and tensioner
4x4 steering rack
2wd crank pulley
i do have other bits and will add them as i think of them.
4x4 steering rack
2wd crank pulley
fuck me thats one smashed up saph.. thats the only problem with 2wd alot more fun but a hell of alot more dangerous. how did you do it mate if you dont mind me asking..glad your ok tho fella
i was putting it against a bike (cbr600rr) and needed to jump on the brakes at ***mph because i was catching him a bit fast and he had broke hard in front, the brakes were'nt right and pulled me across the road, i let off thinking it would pull itself right then the car decided to go the other way, then i lost it hitting the barriers...whoopppssssss....
Up under the rear beam on the drivers side is a valve in the brake system - fits vertically in the pipework - looks like you can almost see it in your pics mate. What a smash - glad you are OK.
pm me a price if you wanna sell it pls
bttt
any 1 interested in the engine??? as i can't find a shell so if someone wants the engine???. the rest of the bits will be forsale after the engine is sold.
standard but mint 205 bottom end with no wear, head is standard but has just been rebuilt and fitted cometic head gasket with all receipts (Ł500)
no rattles or smoke from cold or warm.
looking for Ł1300ono for it complete with everything that bolts onto it (vernier pulleys, clutch, flywheel, alternator, power steering pump, inlet manifold with fuel rail and a choice of a 2wd or 4wd exhaust manifold) no turbo or gearbox
will sell turbo after engine sells t34/63 just been rebuild 10 miles ago with new bearing housing new shaft and 360 bearing kit.
