Best place to put oilcooler
Old Aug 19, 2008 | 10:37 AM
Red_bull's Avatar
Red_bull
Default Best place to put oilcooler
Hello Guys,
What is the best place to go with a oilcooler? I have seen pics with oilcoolers behind the rad, but i don't think that is the best place for them to go?! Close to the turbo and behind a big IC and Rad..
Where did you place them or what is the best place in your opinion?
Old Aug 19, 2008 | 11:11 AM
robj20's Avatar
robj20
OS wing is ideal.
Old Aug 19, 2008 | 11:49 AM
Red_bull's Avatar
Red_bull
could you post a pic or a desription with it because my english isn't good enough to understand your post
Old Aug 19, 2008 | 11:51 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You put it in the path of airflow...... it's a heat exchanger/radiator!
Old Aug 19, 2008 | 11:54 AM
Red_bull's Avatar
Red_bull
Yeah but where do i get the best airflow? The front is blocked with the IC and Rad so that means i have to get on the back of them or move it to the sides but i don't know if i get enough airflow
Old Aug 19, 2008 | 12:14 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
People have mounted them on the Right hand (OS as said) inner wing and move the ignition coil IIRC...
Would need an air feed if fitted there though.
Old Aug 19, 2008 | 12:17 PM
lead_foot's Avatar
lead_foot
is awesome
On the front bumper like this?
Old Aug 19, 2008 | 12:20 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
^^ Went for the subtle look
Old Aug 19, 2008 | 12:24 PM
lead_foot's Avatar
lead_foot
is awesome
Not really no.
and now it looks like:
Old Aug 19, 2008 | 12:38 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
If you don't get enough airflow through your radiator, then i'd be a bit more worried about your water temp than your oil temp!
Old Aug 19, 2008 | 01:14 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
lead foot FPMSL
Exhaust is insane...and that clour, looks like it drifted straight between Jordans legs
Old Aug 19, 2008 | 01:48 PM
Red_bull's Avatar
Red_bull
I will have enough airflow but then it's close to the turbo and i have hot air from the intercooler and rad comming through my oilcooler... so that's more an issue to me
I'm going for the other option i think
Old Aug 19, 2008 | 02:11 PM
project rs's Avatar
project rs
they fit inside the drivers side wheel well. take your front bumper of and you'll see there is nothing in there and gets lots of nice air and if needed a little fettle with bumper will make sure all the air you want will get there you can't use passenger side as washer bottle is there
Old Aug 19, 2008 | 02:41 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Originally Posted by lead_foot
Not really no.
How wide are them rears!
As for oil cooler place, as said. By the OS wing with some fans ontop. Failing that, how much oil line you got? You could mount it at the front, by cooler or just under slam panel with some fans on it to help.
Old Aug 19, 2008 | 04:12 PM
gus's Avatar
gus
mine is in the front bumper
not plumbed in yet, but you can see where the in / outlets are (red bits)
Old Aug 19, 2008 | 05:10 PM
Red_bull's Avatar
Red_bull
No need to take the bumper off, it is allready and i just wanted to know if there was enough airflow!
Will have to look if i have enough oil line and i don't want do drill in my new bumper
Old Aug 19, 2008 | 06:53 PM
dave_y's Avatar
dave_y
Old Aug 19, 2008 | 06:59 PM
Gregor's Avatar
Gregor
Just put mine here.
No real airflow but with some small fans on it and mabe a cold air feed we'll see how it goes.
Otherwise it'll have to go in the wing or something as said before.
Old Aug 19, 2008 | 07:09 PM
Micky's Avatar
Micky
Originally Posted by Gregor
Just put mine here.
Thats a complete waste of time putting that oil cooler there,you may aswell fitted it in the glovebox!!!Regards,micky
Old Aug 19, 2008 | 07:13 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Don't say that, you'll upset the majority
Old Aug 19, 2008 | 07:33 PM
Red_bull's Avatar
Red_bull
@ Dave Y
Thanks i think i'm going to copy your idea
Old Aug 19, 2008 | 07:36 PM
Charlie Chalk
Unknown.
Drill out some massive fucking holes in the inner wing, would help for flow LOL
Old Aug 19, 2008 | 07:47 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
fans on your oil cooler is retarded.
the time when you NEED oil cooling is the time when you should have airflow.
if not, youve put it in the wrong place.
fans cant keep up with shit, as said, may as well put it in glovebox, or up a cats anus.
Old Aug 19, 2008 | 09:16 PM
Tim's Avatar
Tim
this was from a year or so ago
Old Aug 19, 2008 | 09:24 PM
Alex_86's Avatar
Alex_86
take it where dave has it
Old Aug 19, 2008 | 09:35 PM
rst in breaking's Avatar
rst in breaking
seen a few mounted on the side of the passer inner wing (engine bay side)
Old Aug 20, 2008 | 05:12 AM
Gregor's Avatar
Gregor
Thought about where to place it and saw a few rst's on here that had it there so assumed it would have at least some effect with an airfeed.
I haven't got any space in the glovebox though... that's where my ecu sits
Never thought of the idea like project RS and dave y ... will put it there and modd the bumper a bit for some airflow.
Old Aug 20, 2008 | 06:48 AM
vibrating_cake's Avatar
vibrating_cake
the intercooler on a megane TD / megane scenic TD is located in the same place basically and that seems to work =) no vents in that location nither
Old Aug 21, 2008 | 08:33 AM
raycov's Avatar
raycov
when fitting a oil cooler on the front of the car ,ie in front of rad,or under the wing, does it effect the oil pressure
Old Aug 21, 2008 | 08:48 AM
lead_foot's Avatar
lead_foot
is awesome
No.
Old Aug 26, 2008 | 08:16 PM
mark-rst's Avatar
mark-rst
Mine is where dave y's is, i have a 13 row in there with no problems.
Oil temp is never an issue on mine at all
Old Aug 27, 2008 | 08:36 PM
Gregor's Avatar
Gregor
got mine where dave y 's got it ...
Better than first attempt lol...
Old Aug 28, 2008 | 11:48 AM
Linsay's Avatar
Linsay
Mine is in the same place as Tim's
ford thought it was a good place for a cooler
approx 90 degrees on track says it works
Old Aug 28, 2008 | 12:04 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
So you're saying you rag your car around a track with a less-than-ideal oil temperature?
Let me find me flamesuit.
Old Aug 28, 2008 | 04:58 PM
Linsay's Avatar
Linsay
it's around 80 degree's normal driving and defi warning is set at 100 degrees - ok to me
3 National days, 2 Crofts, 2 Ring trips and various other trackdays haven't killed it yet
Old Aug 28, 2008 | 05:05 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
sticking it on the inner wing,doesnt the air being sucked thru the vent not cool it?just it running thru the cooler not cool the oil enuff??
Old Sep 3, 2008 | 07:02 PM
Red_bull's Avatar
Red_bull
with fitting the oilcooler sandwith plate do i have to lose the old oil to water sandwichplate? and do i have to connect the two hoses together?
Hope someone can tell me
Old Sep 3, 2008 | 08:10 PM
Micky's Avatar
Micky
Sticking it on the inner wing is a complete waste of time and WILL NOT give you cool oil temps.Regards,Micky
Old Sep 3, 2008 | 08:25 PM
project rs's Avatar
project rs
what temps should you be looking to keep your oil around
Old Sep 3, 2008 | 08:33 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
project rs- 100-105C when on it.
