newb, some help please
Old Aug 18, 2008 | 11:34 PM
louisjames's Avatar
louisjames
Default newb, some help please
hello there, just got a s2 zvh mk4 running mfi, i also have a mk5 with zetec 2.0 efi.
i want the turbo engine dropped in the mk5, what is the easiest way to have this done? and can the efi system just be added on to the zvh (as its all in the car)
any help appricicated. cars are going in thursday for the work so would like to let the guys know which option to go with. thanks
Old Aug 19, 2008 | 01:49 PM
orion88's Avatar
orion88
you will need to put the mfi wiring in the mk5 an efi and mfi are very different also the mk5 will be running zetec so unless the mk4 is a zetec turbo and not a cvh head on a zetec bottom u will need to do the wiring
Old Aug 19, 2008 | 09:39 PM
rst in breaking's Avatar
rst in breaking
i think you'd be better off converting the zvh to efi as the cab runs efi so you would need to change engine harnress and ecu from a fiesta turbo, flywheel and some adapter plates
Davemurphy007
22
Jan 1, 2016 06:51 AM
jonny jones26
May 4, 2015 04:37 PM
Alicavi Cavi
Oct 23, 2013 11:39 PM
simon513
May 4, 2013 05:27 PM
fridgeman
Ford Classics & Vintage
20
May 15, 2010 02:12 PM
