3dr electrics problem!!!
Old Aug 17, 2008 | 07:59 PM
JoeRS22's Avatar
JoeRS22
Default 3dr electrics problem!!!
hey people found the nightmare burnt out fan fuse today and also dodgy headlight relay going into fuse box,
how does the fuse box come out????
Old Aug 17, 2008 | 10:28 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I wouldnt bother pissing about trying to repair the fan fuse holder, I would just make your own seperate wiring loom for the fans with thicker wire and with each fan with its own relay and fuse.
Made a new fan loom for mine and its spot on!!
As for the headlights, have you tried changing the relay?
Old Aug 18, 2008 | 06:42 AM
JoeRS22's Avatar
JoeRS22
Default yo gaz
tried swapping it with another one and the same, dodgey connection on base
as for the fuse when you gona make me a loom?????
oh and my boost has gone from 15psi to 25psi that t3 screams and so do the tyres in 2nd gear, its destruction time see what breaks first!
Old Aug 18, 2008 | 06:50 AM
As said about the fan loom, piss easy job to do, as is a fuel pump rewire(also needed).
The fusebox terminals can be replaced if you have a DE POPULATOR TOOL, sometimes can do it with a small screwdriver, fusebox comes out after undoing four nuts around the edge on the indside of the car, they do not pull up much though, but just enough to swap a terminal.
Headlight relays usually ok on these, the terminal block on the headlight suffers terribly though with bad connection, especially earth.
Old Aug 18, 2008 | 06:58 AM
JoeRS22's Avatar
JoeRS22
Default cheers!
thanks mate i think the earth on the headlight is the problem i will attempt removing this week the fusebox!
Old Aug 18, 2008 | 09:09 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I can make you one if you want. Ive got another 2 or 3 to do for people anyway so it aint a problem.
As soon as I get a little time to meself, I'll make one.
Old Aug 18, 2008 | 09:29 PM
bad boy rs's Avatar
bad boy rs
Dont forget me
i need a new fan loom and fuel pump loom
will it be in gr performance braiding ?
Old Aug 18, 2008 | 09:35 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Originally Posted by bad boy rs
Dont forget me
I'll be using sellotape on yours!!
Old Aug 19, 2008 | 06:08 AM
bad boy rs's Avatar
bad boy rs
That wouldnt suprise me !
some of the bodges ive seen you do in the past !
mastic / super glue / bluetac
Old Aug 19, 2008 | 02:04 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
You forgot gaffer tape in that last statement.
Proper job!
Old Aug 19, 2008 | 08:17 PM
JoeRS22's Avatar
JoeRS22
talk to me about the loom gary ive got a rolling road booked very soon and need it done....... ?????
Old Aug 19, 2008 | 09:17 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Shouldnt take long to do it.
When is your car booked in?
Old Aug 20, 2008 | 06:24 PM
Mike1's Avatar
Mike1
Dont forget me
Has anyone got any pictures of the braided wire type ones? Who can make one and how much would it cost?
Mike
Old Aug 20, 2008 | 09:06 PM
JoeRS22's Avatar
JoeRS22
Default QUICKLY!!
early next week, i dont think me t3 is gona last at 25psi at the mo it whines like a bitch
Old Aug 20, 2008 | 10:05 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
You love it!
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Sierrasideways
Oct 8, 2015 06:37 PM
S3an
Sep 26, 2015 11:39 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
