xr2 unfinished project
picked this up today. Its a fairly straight car but does need some love. Biggest issue is the clutch will not engage so needs to be picked up on a loader / trailer. Other than that it basically needs tidying.
It has a small hole in the boot floor, and one in each inner sill. the reat of the floor looks very tidy, and it has had one new rear arch in the last couple years i think as its more solid that the other side. The other side isnt that bad really thou. Sills appear pretty solid. Its had a pair of wings about 2 years ago, the welds in the door close are not so good thou, easily sorted with rust killer and a squirt of paint thou, it just looks like the person who did it did not paint them. The inner wings are pretty good bar a patch at the front of one that needs cleaning back and painting and a small hole in the front on the other side. Both doors are a bit minging tbh. Its missing some interior too, but thats easy to get cheap.
I have prob made the car sound alot worse than it is, it is very solid in the right places, it just needs some love in little areas, just tried to be as honest as possible.
Spec wise its fairly standard, lowered about 40mm, has a mild steel sportex system and a 4 branch, and k&n fitted.
Looking for £350 really, if you free off the clutch and do so tiny bits of welding it will fly though a MOT and would be worth £800 I reckon. This car would clean up really well. If I could be arsed to sort the clutch then I would do the other bits too lol.
£350.
£350.
Kiran1600E
11
Oct 2, 2015 11:35 AM
SMILER258
Sep 28, 2015 09:04 AM
