Polybush beam mounts. Is this right?
Old Aug 15, 2008 | 12:39 PM
Char1ie's Avatar
Char1ie
Default Polybush beam mounts. Is this right?
Have I fitted this Powerflex beam to body mount bush correctly? First pic shows Ford bush removed with Powerflex bush and second shot shows Powerflex bush mounted in position. Have I done this right? Seems like the bush is much bigger and the bolt is difficult to get in and difficult to do up. Have I made a mistake? Is it upside down?
Thanks,
Charlie
Old Aug 15, 2008 | 01:46 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
Yep its correct. When you put it on jack the beam up on to the car to get the bolt started on the thread
Old Aug 15, 2008 | 02:57 PM
Char1ie's Avatar
Char1ie
Cool, thanks. Doing it now.
What do I do if I can't get the original Ford bush out of the other side?
Charlie
Old Aug 16, 2008 | 06:55 AM
Just cut any that won't come out if you don't need them anymore.
Nov 1, 2015 06:53 PM
DavidK
Sep 27, 2015 02:55 PM
Russp
Escort Range
Sep 18, 2015 07:39 PM
truffleshuffle
Sep 10, 2015 09:35 PM
3doorcozmess
Sep 7, 2015 01:32 PM
