Anyone name this part
Old Aug 14, 2008 | 07:07 PM
motherhupit's Avatar
motherhupit
Default Anyone name this part
Its of a FRST OFAB and sits behind the Jack on the right hand side of the engine bay, Looks knackered as the 2 yellow wires have been joined together rather than going to the unit has always been like this and runs lumpy once unplugged,
Any Ideas as i would like to know why it has been joined up this way
Cheers Seb
Old Aug 14, 2008 | 07:08 PM
crazycage's Avatar
crazycage
is it off the abs ??
Old Aug 14, 2008 | 07:09 PM
motherhupit
Nah no ABS on the car, don't think so anyway as it affects cars idle and running
Old Aug 14, 2008 | 07:21 PM
Could be a surpressor, BERU normally make ignition components.
Old Aug 14, 2008 | 07:39 PM
motherhupit
OK so why would he have the yellow wires just shorted together, and why would it make the car run so lumpy, could it just control the igition system or something simular
Old Aug 14, 2008 | 07:52 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
The black connector looks very similar to the speed sensor connection I had on my Escort.
Old Aug 14, 2008 | 07:58 PM
The DIVA's Avatar
The DIVA
Octane/Idle adjuster plug most probably.....
Old Aug 14, 2008 | 08:12 PM
motherhupit
Yeah maybe i seen on the wiring diagram that there is a octance adjustment thing on that side of the wing but i've never heard of one before or what and how they adjust things, maybe
Old Aug 14, 2008 | 08:16 PM
motherhupit
Just had a look at the wiring diagram again and they should be brown yellow, brown black and brown red, But i have brown yellow, brown, yellow so not sure if its the octane adjust
Old Aug 14, 2008 | 08:26 PM
motherhupit
Ok i've notiched that its only affects the running of the engine weather it be plugged in or not when warm when cold on choke etc, it doesn't seem to make much on a difference on idle that is anyway, gonna try connecting it up propaly and seeing the Difference will let you know tommorrow, Any more ideas in the mean time would be great
Cheers SEB
Old Aug 14, 2008 | 08:37 PM
sortedsaff's Avatar
sortedsaff
belive its suppressor linked to the map sensor i think .
it says abit about it on rsbible
Old Aug 14, 2008 | 09:15 PM
motherhupit
Cheers mate looks like you might have solved gonna go for a test run tommorrow cheers
gambo08
Feb 4, 2016 10:49 PM
Oct 1, 2015 02:00 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fordmad!
Sep 29, 2015 07:03 PM
