Special offer on Coolboost
Old Aug 14, 2008 | 06:27 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
Default Special offer on Coolboost
R.R.P. £17.61 including VAT
SPECIAL OFFER - £14.99 INCLUDING VAT. We will be at National Day, so you can pick if up from there or postage is £4.50 to UK locations.
Coolboost improves both the efficiency and performance of your engine by giving better surface contact between the coolant and metal surfaces.
Coolboost gives a 10% improvement-bare minimum, as proven in all performance car tests.
Coolboost is well known as a performance product when used in radiator systems, another area it is proving to be an outstanding additive is high performance cars using charge cool systems. When added to the coolant side of charge cool kits its performance properties aid cooling.
Coolboost contains inhibitors to protect modern aluminium engines cooling systems, and therefore is beneficial when added to aluminium charge cool systems. Although coolboost contains no anti-freeze properties it can be used in conjunction with anti-freeze.
The (just add) coolant performance booster increases power and helps prevent over-heating, and is one of the most cost effective performance coolants additives on the market today.
Call us on 01582 696 111 (10:00am-10:00pm) if you want to place an order. We accept payment by Credit/Debit Card.
Natalie
Rapid-Ford
sales@rapidford.co.uk
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
Nick 172 Sport
Sep 28, 2015 07:21 PM
