Turbo pipes help!!???
Aug 14, 2008 | 09:42 AM
i think the bloke who i got my rs off had a bleed valve or sumert on it...but now it hasn't as im to small rubber pipes comin from near the turbo>? any no what i connect them to lol?
thanks.
Thats the 1 off the actuator.....
Thats the 1 off the bottom of the turbo...
And these are cut too, the top 1 and the 1 with the jubilee clip.....
The very bottom 1 is connected to the fuel metering unit...
Aug 14, 2008 | 10:14 AM
edited cos now you've added pictures
Aug 14, 2008 | 11:30 AM
theres a pipe comin off the actuator and 1 comin off the turbo both look like they've been cut just wondering what they conected to?
Aug 14, 2008 | 12:32 PM
Best to put a picture up and then you'll get the right answer.
Aug 14, 2008 | 03:47 PM
sure mine come off actuator and turbo and go into the bottom of metering head.
correct me if im wrong but from memory mbc are 2 way and bleed vs 3 way????????
dave
Aug 14, 2008 | 05:47 PM
Hope this helps. thanks.
kev.
Aug 14, 2008 | 07:35 PM
Aug 15, 2008 | 07:01 PM
yeah the pipes shoud go to the Amal valve that you have the cut pipes on!
Should go like this!
Aug 16, 2008 | 03:18 AM
orrrr man thanks alot pal!!!!!! much apreciated....
Aug 16, 2008 | 09:21 AM
No worries!
Aug 16, 2008 | 11:53 AM
so is the amal valve what the bleed valve or mbc actually replaces?
Aug 16, 2008 | 01:40 PM
that's a easy one to help some one out! Could use it atm! Thanks!
s1cab
Jul 26, 2018 06:11 PM
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
andy130
Oct 2, 2015 08:48 PM
Matt Baxter
Sep 16, 2015 08:30 PM
AndrewStrang
Sep 1, 2015 11:16 AM
