Suspension kit for the S2
koni adjustable shocks are great but the springs you get are too soft and makes it harsh on bumpy roads currently got spax springs with my adj koni's and is better but still not there yet
"koni adjustable shocks are great but the springs you get are too soft and makes it harsh on bumpy roads "
That doesnt make any sense, your springs determine the ride height and your shocks determine the ride quality (ie:harder or softer), unless the springs are fucked and make the shocks bottom out on bumpy roads!!??
no need for coilover if you gone use it as a daily drive!
koni is a ok kit, have that my self! order the adjustable so you could adjust the harness.
dont lower more than 35mm.
could also be an idea to change the bushes when you are at it!
Getting my front suspension done now, my front driver`s side shocker died so replacing the koni adjustables that must`ve been on my car for years. Got new koni adjustables and spax springs -25mm as had -35mm on previous and wanting to make the S2 a bit more speedhump friendly as they fking everywhere around here now
Hoping to get call any minute now to gan collect it and see what its like. I`ll post my verdict on them later on mate
I did order full adjustable koni kit from autotintdesgin.co.uk and what i get was 4x koni adjustables and lesjöfors springs.. anyone heard these before?
I have kit still in package and i think i will install these in winter
id be interested to know whats the best set up as im just going to order up my koni set but if i can get a better ride quality using different springs il just get the shockers and order a different set of springs.be good to know what the outcome will be.
SMILER258
Sep 28, 2015 09:04 AM
