Where does the sunroof drain into?
Wye Valley Hardcore
I've got a problem. The carpet behind my passenger seat in the rear foot well is soaking wet when ever it rains or I wash the car. I've had the carpet up and theres no holes in the floor so dont know where the wet is coming from. And its not just damp, its saturated.
Anyone had this problem or know where its coming from. Seats, headlining etc are bone dry and its only this bit of carpet that is wet.
is there any holes in the inner sill the sun roof drains into the sills my rs does the same
i never sorted mine it,s been in the garage for the last 6 months coz somone wiped it out and now lost intrest after building it for a year
check for rust holes under the battery tray,could leak through, and if you park the car on a hill could run straight behind the back seat,make sure drain holes in the cills are clear!
the front pipes run into the sill
make sure all the holes underneath are clear
if its had new inner sills fitted it will leak
or drill a large hole at the front of the sill and put a large pipe in it for the sunroof drain pipe
on the rear the s1 drains into the lower rear quarter and the s2 drains out the lower rear quarter
