RS500 spark plugs in cvh
Old Aug 13, 2008 | 08:22 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default RS500 spark plugs in cvh
im plannin on puttin the plugs in my series 2 im runnin 200 brake with group a coil but the standard plugs are not good for the job, will these be ok?
Old Aug 13, 2008 | 08:25 PM
BigErn's Avatar
BigErn
Cossies and RST's run the same plugs iirc. Why are your plugs no good
Old Aug 13, 2008 | 08:30 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
well thing is went silverstone car ran fine on way there but started to missfire on light throttle, even if i hold on 3.000 rpm it missfires had car set up 3 weeks ago was fine when left jamsport
Old Aug 13, 2008 | 08:32 PM
T28 RST's Avatar
T28 RST
Ok then
NGK Bc8res
Old Aug 13, 2008 | 08:34 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
as Above, NGK gapped to about 25thou, good enough for 500bhp cossies, good enough for a 200bhp RST!
Old Aug 13, 2008 | 08:41 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i have a group a coil will t matter about the gap, think it is point 6? im thinking it is the rotor arm?
Old Aug 13, 2008 | 09:03 PM
juffer's Avatar
juffer
You cant go far wrong with these. Im using them and i know a fair few people also using them. Buy them from ford tho as you will get them for half this price !!!
http://cgi.ebay.co.uk/SPARK-PLUGS-St...6.c0.m14.l1318
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
