which colour zetec bearings?
Just been to order some main bearings, they asked which colour i had!? i had no idea so have come back to check my old ones.
Microcat list 4 different ones:
green
brown
yellow
blue
Engine is a Focus ST170
my old bearings so seam to have a blob of what looks to be brown paint on the edge of the bearings. is this the only way to tell them apart? It has these numbers stamped on the bearings:
938M 6333 C1B
any ideas or do i just go for the brown so to speak
green
brown
yellow
blue
938M 6333 C1B
cranks been away for a check and has come back fine. changing shells whilst engine is apart before its built up
have looked at some more and am now not sure if its a dirty yellow rather than a brown lol
they do give measurements too at :
2.148-2.141
2.145-2.138
2.140-2.133
2.135-2.128
mate has some digital vernier calipers shall i just measure the bearings and go from there?
2.148-2.141
2.145-2.138
2.140-2.133
2.135-2.128
mate was a no show with verniers. I have managed to get the chasis no. from the car the engine came from. Off to fords at dinner to collect some other bits, so will see if that will show just one bearing up!?
been to ford, he thought brown too. Put part number into microcat and it brought up yellow. It did this for the lower and upper bearing so yellow it was. The center bearing had no part numbers that microcat knew so went with yellow again. 10 days order from germany for most bits
