General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I've got a 150, check the engine is a ARL, the 150 will be a tad lower as well as they are GTI springs as standard, also the boot sticker should say 110kw
Dont take no notice of the colour of the badges, i have a 150 TDI and on the back it has a silver GTI badge under the bonnet all red TDI, i also have a 115 with the TD on the boot red and the I silver, same under the bonnet
If you are looking for a 150 model speak to Rob from SCC (01727 867747), he has a 150 "02" plate 3 door modded to just over 200bhp and still delivers 44mpg, also has the anniversary wheels and kit. It's also had the cam changed in the last few months as it did exactly what has been mentioned above, I know he was thinking of selling a few weeks ago.
Why do ppl think the 130 is a better car?? The 150 has FMIC, bigger turbo therefore much better for modding etc.
I've had mine for 3 years now covered over 65k and never had any problems with cam (remapped miles). I've changed the oil every 10k and never had a problem with cam or turbo. Recently I've started modding for further power - see sig for further info.
I would def recommend the 150 - speaking from experience.
I only say 130 due to the cam probs, my cam was changed by previous owner so no experience in them going personally just the reading up i done before buying.
I have a 150 BHP TDI and it ate the cam after 80,000 mile,I wouldnt mind,but it was always serviced correctly,every 6-8,000 miles,using the correct Castrol SLX oil,which I might add cost a poxy fortune,(virgins p*ss would be cheaper)!!!!!Anyhow up to the cam failure I loved the car,but now Ive lost all faith in it,and VW's for that matter.It was my 1st VW,I guess I got sucked in by all the hype about the build quality!!Never again!!Regards,Micky
The PD 130 and PD 150 is pretty much the same engine. Its my believe ppl dont change often enough resulting in these cam problems. I know VW have long life servicing (20k) but I think if you want hassle free motoring change the oil every 10k.
slightly of topic ,
in the pic of the 150 engine bay , what are the tiewraps for on the boost hose !!, next to the cam belt cover ,
just an observation i noticed
slightly of topic ,
I'm guessing they are used for holding the boost pipes on. With age the lugs on the pipes get worn out which cause the pipes to slip off with boost.
