Rear hubs nut torque setting
Old Aug 12, 2008 | 12:32 PM
Rippers's Avatar
Rippers
Monte Geek
Default Rear hubs nut torque setting
IIRC its 320-350lbs on the Esc Cos can anyone confirm that, seems high?
Do new bearings need beding in or anything?
Old Aug 12, 2008 | 01:03 PM
Brian ST-2's Avatar
Brian ST-2
Thumbs up
Paul,
Your local Ford dealer should gladly tell you what the hub torque settings are, but from my experience rear ones are so tight cos they're non adjustable. Not like the old tapered roller bearings.
Plenty real techy guys on here should be able to confirm though.
Brian
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
rst-s1
Aug 23, 2015 07:56 AM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
