Floot well Repair - More small patches or one new large patc
Old Nov 5, 2004 | 12:25 PM
V6's Avatar
V6
Default Floot well Repair - More small patches or one new large patc
Hi
Can anyone advise on the best course of action?
Should I patch with more small patches or cut the lot out and put in one large new section?
I was leaning towards a new large section
Also my only option where I do the work is my driveway - I was looking at getting a gas MIG - any advice for outside welding?
V6
Old Nov 5, 2004 | 12:51 PM
zvhturbo's Avatar
zvhturbo
I'd replace the whole section mate.
If welding out side make sure you keep out of any wind or it will blow the gas away and won't weld very well at all.
If you still have problems use gasless wire which has a flux core and you can use in light wind.
Matt.
Old Nov 5, 2004 | 02:34 PM
V6's Avatar
V6
Thanks Matt
The only thing I am bothered about is the contition of the plate under the floor which is used for jacking
You can see the top side of this where the green and pink wires cross the hole. It looks very difficult to make another if it is totaly corroded
Daz
Old Nov 5, 2004 | 09:40 PM
chiz's Avatar
chiz
as zvh turbo sais stop the wind and ur cool
do ya mean the jacking points fooked?? its kinda hard to see wats goin on in second pics, but if its a chassis leg jacking point thats away u could order a new one from a supplier, cant think who off top of head.
Old Nov 8, 2004 | 07:13 AM
V6's Avatar
V6
Yeah chiz it's the front jacking point, where the standard ford jack goes in, but it is also the area between that and the sill where a pillar lift would lift from.
The pics are a bit poor I only had my phone on me at the time, the camera's not the worst but definatley not the best!
I'll get some better shots
Daz
fordrallycar
Sep 30, 2015 07:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
