pics of N/A cosworth engines
Old Aug 12, 2008 | 09:15 AM
RSCossieGaz's Avatar
RSCossieGaz
Default pics of N/A cosworth engines
has anyone got pics of any n/a cosworth engines ie pics of the engines in the engine bay?
Old Aug 12, 2008 | 10:34 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Heretic!
I think I have a few on my photobucket from a track day a while back - will have a look for you.
Google found this one though:
Deviant...Pure deviant...
Old Aug 12, 2008 | 10:49 AM
ian sibbert's Avatar
ian sibbert
Escort mk 2 install
Old Aug 12, 2008 | 11:09 AM
richard_syko's Avatar
richard_syko
What about ...
Nice
Old Aug 12, 2008 | 04:02 PM
AustenW's Avatar
AustenW
serious numbers there
Old Aug 12, 2008 | 05:15 PM
ÖmerRS's Avatar
ÖmerRS
Is this escort around 400 ps? N/A ? amazing.
Old Aug 12, 2008 | 06:22 PM
boXXer's Avatar
boXXer
GASH!
yeah, and revs like a bastard!
Old Aug 12, 2008 | 06:31 PM
Ricky rs's Avatar
Ricky rs
fukin awsome
Old Aug 12, 2008 | 08:23 PM
broadmoor's Avatar
broadmoor
A couple of my mates run N/A YB's on Slide ..I only have these pics tho..
Old Aug 12, 2008 | 09:24 PM
AustenW's Avatar
AustenW
Whats the stroke of the Greek engine for it to rev to 12k
Old Aug 12, 2008 | 10:25 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Look at the fookin rods! Proper Top Fuel spec rods, dont think itd matter the stroke, theyd handle it!
Old Aug 12, 2008 | 11:09 PM
richard_syko
did read it runs on MotoGP fuel cannot get any spec for that though
Old Aug 13, 2008 | 06:01 PM
AustenW's Avatar
AustenW
Whats the spec of the Greek engine?
Old Aug 13, 2008 | 06:43 PM
ÖmerRS's Avatar
ÖmerRS
I found this. translated in english
We are presenting today a separate Escort MKII which runs mainly on sirkoui. We are presenting today a separate Escort MKII which runs mainly on sirkoui. The lucky owner of the Escort is very possible Spyros Papadopoulos of Kalamata. The lucky owner of the Escort is very possible Spyros Papadopoulos of Kalamata.
"Our goal was to build a motorized system with maximum efficiency by 1999cc, which is the upper limit allowed in a class struggles" says Spyros and continues: "Our goal was to build a motorized system with maximum efficiency by 1999cc, which is the upper limit allowed in a class struggles "says Spyros and continues:
"The best motors, which brought in MKII context was the Cosworth. So we started and looked for the motors that what would be required to pay the maximum from construction materials and geometry of motors. As the motorized design perspective has to pay more than 250Hp per litre in the form of air. "The best motors, which brought in MKII context was the Cosworth. So we started and looked for the motors that what would be required to pay the maximum from construction materials and geometry of motors. As the motorized design perspective has to pay more than 250Hp per litre in atmospheric form.
Thus, we designed the geometry of motors can be operated until 13,000 rpm Thus, we designed the geometry of motors can be operated until 13000 rpm without problem. without problem. The materials, of course, chose not exist in trade and we have special construction. The materials, of course, chose not exist in trade and we have special construction.
The motorized ypokyvistike to 1914cc (92mm x 72mm). The motorized ypokyvistike to 1914cc (92mm x 72mm). The bieles longer than a specific type of aluminum alloy. The bieles longer than a specific type of aluminum alloy. The pistonia Supertech is also a special alloy and resistance until 35m/sec linear speed with 17:1 compression. The pistonia Supertech is also a special alloy and resistance until 35m/sec linear speed with 17:1 compression. The strofalos steel is made with our own standards and geometry. The strofalos steel is made with our own standards and geometry. The valves are titanium, while Supertech ekkentroforoi is also special order. The valves are titanium, while Supertech ekkentroforoi is also special order.
The supply of oil arrange a dry casings. The supply of oil arrange a dry casings. The tetrapetalouda Our bodies are built, and the system of export (octopus - evaporation). The tetrapetalouda Our bodies are built, and the system of export (octopus - evaporation).
We use more brain Haltech E8 with sequential spraying. We use more brain Haltech E8 with sequential spraying. As understand there are many features of motors, which, while having great interest, we can not disclose. As understand there are many features of motors, which, while having great interest, we can not disclose.
In setting the dynamometer, 412hp motors attached to 11500 rpm In setting the dynamometer, 412hp motors attached to 11500 rpm and 28.18 kgr torque at 9700 rpm and 28.18 kgr torque at 9700 rpm with fuel from MotoGP. with fuel from MotoGP. We believe that the motors that is not in final form, and one in the near future, with some changes, we will increase the ippodynami of aspiring to 480 Hp at 12800 rpm We believe that the motors that is not in final form, and one in the near future, with some changes, we will increase the ippodynami of aspiring to 480 Hp at 12800 rpm
Our objective was to build a motorized global concern that compete mainly very good atmospheric Japanese motors. Our objective was to build a motorized global concern that compete mainly very good atmospheric Japanese motors. Ekmetalleftikame a very large percentage of the speed of sound and the 2 and 4 the impulsive wave. Ekmetalleftikame a very large percentage of the speed of sound and the 2 and 4 the impulsive wave. Of course there is still a small margin, which if the exhaust will overcome 250Hp per litre. Of course there is still a small margin, which if the exhaust will overcome 250Hp per litre. In this case, however, the motors will work marginal and will not be suitable for speeds match. In this case, however, the motors will work marginal and will not be suitable for speeds match.
In terms of transmission have chosen a isogranazo Quaife with the rear differential also Quaife. In terms of transmission have chosen a isogranazo Quaife with the rear differential also Quaife.
The level of improvement in the area has risen enough and continues to grow day by day. The level of improvement in the area has risen enough and continues to grow day by day. I think now we have something to zilepsoume from foreign veltiotes. I think now we have something to zilepsoume from foreign veltiotes. I also believe that the level of improvement in Greece, if not the best, one of the best in the world. I also believe that the level of improvement in Greece, if not the best, one of the best in the world.
Spyros Panopoulos - Spiros Papadopoulos Spyros Panopoulos - Spiros Papadopoulos
Extreme Tuners - Papadopoulos Power Extreme Tuners - Papadopoulos Power
Old Aug 16, 2008 | 05:02 PM
rs_fiesta's Avatar
rs_fiesta
Originally Posted by ian sibbert
Escort mk 2 install
Darren Atkinsons?
Old Jan 20, 2010 | 03:07 PM
AustenW's Avatar
AustenW
Any more?
Old Jan 20, 2010 | 04:49 PM
Sharkey's Avatar
Sharkey
Here`s mine soon to be fitted
Old May 29, 2010 | 03:06 PM
fridgeman's Avatar
fridgeman
heres mine,
Old Aug 16, 2011 | 02:16 PM
AustenW's Avatar
AustenW
any more?
Old Aug 16, 2011 | 04:38 PM
ROBnoTOP's Avatar
ROBnoTOP
Lost for life.....
Seen it on FF.....
Old Aug 16, 2011 | 04:51 PM
fridgeman's Avatar
fridgeman
thought that looked nice,its mine.
Old Aug 16, 2011 | 04:58 PM
boXXer's Avatar
boXXer
GASH!
Lol, was Gunna say thats pigs old car. Millington diamond power, yummy
Old Aug 16, 2011 | 08:33 PM
bubs_rsturbo's Avatar
bubs_rsturbo
maybe a stupid question but whats the benefit of ditching the turbo??
Old Aug 17, 2011 | 09:59 AM
SHIFTY rsoc's Avatar
SHIFTY rsoc
From: In the workshop or out getting some sideways!
Nice one folks, proper engines and sound the bizz too.
Heres my Wilcox built n/a yb for my mk2...built by The main man John Wilcox himself..
Should be fired up and leaving some black lines soon! lol
Old Aug 17, 2011 | 10:39 AM
boXXer's Avatar
boXXer
GASH!
some nice engines on here...
this is mine..
Old Aug 17, 2011 | 11:12 AM
Eigdoog's Avatar
Eigdoog
ą§~Quadzackular~§ą
Will these not go faster by adding a turbo? How come they dont use one?
Old Aug 17, 2011 | 11:17 AM
Joe Grp4 Escort's Avatar
Joe Grp4 Escort
Old Aug 17, 2011 | 11:21 AM
AustenW's Avatar
AustenW
More responsive and more controllable for rallying in RWD, plus turbo's would put them in a different class with all the subaru's and evo's
Old Aug 17, 2011 | 12:26 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Very nice! were did you get the brake/clutch res mounting bracket from?
Old Aug 17, 2011 | 12:43 PM
SHIFTY rsoc
Thanks mate!, got it from Camillus @ http://www.cbradleymotorsport.co.uk/
Old Aug 17, 2011 | 02:12 PM
gouch1's Avatar
gouch1
some very nice engines there
Old Aug 17, 2011 | 03:20 PM
Rsmat's Avatar
Rsmat
Some stunning engines.
Old Aug 17, 2011 | 03:33 PM
Nice engines.I like them with turbos bolted on the side better though.
Old Aug 17, 2011 | 04:51 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
is that the same greek guys who built the 1200bhp escort cosworth?
Old Aug 17, 2011 | 05:28 PM
Eigdoog's Avatar
Eigdoog
ą§~Quadzackular~§ą
I get it now cheers!
But you say the same class as subaru's and evo's, does this mean they still use this engine for rallying today? Or do you mean how it used to be?
Old Aug 18, 2011 | 08:54 PM
PileOfRust's Avatar
PileOfRust
over 400hp in a n/a 2.0 4pot insane!
a supercharged one would be interesting
Old Aug 18, 2011 | 09:57 PM
blue oval 24v's Avatar
blue oval 24v
Old Aug 18, 2011 | 10:05 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Old Aug 19, 2011 | 12:13 AM
NoRubNoDub's Avatar
NoRubNoDub
they are becoming a rare sight, most top mk2's use a 2.5ltr milinton diamond engine now about 320+bhp
Old Aug 20, 2011 | 01:49 PM
2wd saff cos @ stage 3's Avatar
lovely engines
