Power Engineering "System Two" 1900 blocks
Old Aug 10, 2008 | 09:23 PM
muz's Avatar
muz
Wye Valley Hardcore
Default Power Engineering "System Two" 1900 blocks
Has any one had one and know If they are any good? I'm looking at getting a new bottom end with desent rods and pistons and this has come up, but there seems to be some mixed views on them and blocks cracking. Its a 1600 block thats been re bored to 1900 by PE and fitted with Mahle pistons.
Old Aug 10, 2008 | 11:34 PM
mk3cab's Avatar
mk3cab
i have run the pe engine and a 2.1zvh in my opinion the pe enging is far better it revs better the power is better spread through the rev range just an overhall better drive. the reason why im running the zvh now is due to piston damage when i bought the pe engine and it was cheeper to build a zvh than rebuild the 1.9.
matt
Old Aug 12, 2008 | 05:23 PM
muz's Avatar
muz
Wye Valley Hardcore
Anyone else had experience with one?
Old Aug 12, 2008 | 05:25 PM
GUZZLER's Avatar
GUZZLER
better as a lower boost engine, about 1 bar.
Old Aug 12, 2008 | 05:48 PM
ScORTED's Avatar
ScORTED
Project Money Pit
I've got a n/a one and i was very impressed with it, even with a standard 1600 mfi head and cam on it, it pulled well and revved as well as if not better than a standard 1600, i think the whole bottom end on mine has been balenced though, not sure about the turbo ones.
Old Aug 12, 2008 | 05:58 PM
boXXer's Avatar
boXXer
GASH!
have a word with mr s1 aswell.
Old Aug 12, 2008 | 06:05 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
they use cast pistons and the blocks crack easily
the standard internals power limit is the same has the 1.6 cvh around 260 bhp
they are good for a low boost engine but the max power limits around the same has the 1.6 so what's the point
Old Aug 12, 2008 | 07:13 PM
ScORTED's Avatar
ScORTED
Project Money Pit
i've heard talk of cracking blocks... it that only on the turbo ones... ours has done 80k and the block is fine
Old Aug 12, 2008 | 09:50 PM
muz's Avatar
muz
Wye Valley Hardcore
"they use cast pistons and the blocks crack easily
they are good for a low boost engine but the max power limits around the same has the 1.6 so what's the point"
Thats what I needed to know. Cheers fella. Pointless for me then as I'm upgrading my bottom end as I don't trust it on 18.5PSI.
original
Apr 28, 2026 05:20 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
Old ford
Jul 31, 2015 06:50 AM
