hi all,
i know it probly been asked 100 times before but what would i need to collect to do a 2.1 zetec conversion to my car. at the moment my engine is standerd bar a exhaust and dump valve and k&n....
i would like to build the engine up myself, and collect all the bits over time so there is no large outlay of cash....
also will i still use a standerd s2 gearbox and ecu with this?
thanks alot..... dan
250bhp is a walk in the park for a zetec.. all you need is a set of low compression pistons and some stronger valve springs, et voila!
(engine-wise)
cool!! will i not need to uprate the pistons ect..
also i heard there is a couple of different types of zetec engine to go for (silver top and black top i think) is there a better one of the two or are they the same.. thanks alot for your replys mate..
dan
