Sagging front end on Saff?
Is there naything you can do to stop the front dropping down on a Saff?
Noticed my headlights and grille have all dropped a few mm and leaves an unsightly gap above where it meets the bonnet now?
A mate said this is common on Saffs?
The bonnet's supposed to have a rubber seal across the front, which I think helps hide it a bit.
Also, if your headlights have been out, or if the bonnet latch has been off, they may not be in quite the right place.
Wilsfoci
15
Mar 30, 2016 10:26 PM
FlashRS
13
Aug 31, 2015 06:02 PM
