sierra saphire rs cosworth 4x4 for sale
my car for sale
right i have to sell my 4x4 saff cosworth now so i have put it up on piston heads
its in the rs cosworth section so please take a look and tell me what you all think
spec wise it includes..........
200 motorsport block
long studded
full arp kit
lightened and ballanced crank which has been nitrided for added strength
ballanced shot peened rods also weight matched
high pressure oil pump
low comp pocketed forge pistons 7.2.1 compression ratio
grp a head gasget
polished and ported head (grp a spec)
bd14 and bd16 cams
kent cam pullys
air to air boost controll
t34 with 360* cut back blades and 63 housing in line oil filter
k and n filter and standard air bow with k and n pannell filter
2wd exhaust manifold
inlet manifold is fitted with a spacer to inmprove air flow
grey injectors
grp a fuel pump
rs500 rad tec 60 mm front mount cooler
full stainless mongoose exhaust 3.5 out rolled tail pipe
brembo 4 pots with 330 rotors the calipers are huge people
drilled and groved and green stuff pads on the rear
engine bench dynoed and proven 400 bhp running 29 psi with nearly matching torque
standard gear box front and rear diffs which are in perfect condition and working order
ap 6 paddel clutch
front diff has been webbed to stop it from snapping off
all the tanks and double strut brace
black sfs hoses
bailey turbo damper
face lift moddel
mint recaro leather interior with no stupid holes cut out for gauges
compomotive mo 5 spoke alloys ( 17 inch by 7.5 j wide) all rapped up in perrelli tyres ( brand new)
fully poly bushed
standard factory ford suspention so no harsh bumpy ride just nice and smooth as it should be!!!!
body work wise this is very very very good with no dents or rust anywhere
just had a full sensor change and i mean everyone
full service including
oil ( mobile 1 motorsport 15/50 fully sinthetic as always used )
filter
plugs (densos)
909 motor sport leads
cap
rotor arm
fuel filter
grp a coil
this is a top quality example for a classic car so viewing is highly recomended
priced to sell @ 6850
tax and tested
ALL WORK CARRIED OUT AT ODELL MOTOR SPORT WITH PAPER WORK TO PROVE
any questions please send me a message or PHONE ON 07886481961
this car has had thousands spent on her to make it a top quality motor
LET ME KNOW WHAT YOU ALL THINK
CHRIS
__________________
dump valves are for gays and the confused
long studded
full arp kit
grp a head gasget
bd14 and bd16 cams
kent cam pullys
grey injectors
grp a fuel pump
ap 6 paddel clutch
black sfs hoses
bailey turbo damper
face lift moddel
fully poly bushed
filter
plugs (densos)
cap
rotor arm
fuel filter
grp a coil
tax and tested
CHRIS
__________________
ther are pics on piston heads reg no j897 vfl
sorry but i cant put up pics on here yet haveny worked it out as iam shit on computers
please take the time and have a look many thanks
chris
chris
looks very nice. with a bigger turbo & injectors i rekon that engine will make pretty big power. what brake calipers are they on the front? someone will get a nice cossy there
front brakes are 4 pot brembos with 330 discs and ally bells
the calipers are fucking huge people cant belive how big they really are
the onlt just fit behind the mo's which are 17'' with a et37 off set
and trust me when i say the work
engine wise the man who built it over spec it incase more power was wanted
he said t4 or bigger with 8 greens or some siemens and it will be more than fine
the callipers are proper huge on my car and when i say they work is an under statement
any more info please ask
the car will be at national day on rapid fords stand so please pop over to take a look
swap you for an mitsi evo fook all selling at the moment i have to keep swapping and px to get down the food chain St170 1 view px for a racing puma 2 views people dicking me about now swapped for a mitsi evo 1997 mint with 52k on it. Might see you at National day!!!
Ian
Ian
yeh i will be at national day on rapid fords stand pop over say hello
dont supose anyone wants a full leather recaro trim good condition 350 quid will bring that with me too
hi all, can tell you all that this car is really as good as it looks and the pic,s dont do her any justice at all!! has to be one of the best looking cars about for sale at a reasonable price for the spec (imoa!) and boy does she go some! will miss this when gone!
right just to tell everone the car has just been fitted with a new gear box
box suplied by dan at rapid ford off a left hand drive 4x4 saff he has taken apart
the car was a very very low millage car which only ran standard power
had the box inspected and checked over and all came up fine
to be honest its so tight and smooth i could not belive it
box replaced as 3rd gear said enough is enough fuck this im off
car runs better than ever now
clutch was inspected too and still looks like new
i have known this car for years!! and it has been very well looked after!! i spoke to cris (v man) on friday and think he is crazy to sell it!!!!!!!!!!!!!!!!!!!!!!!!! to much work and money has gone in to it to sell no one buy it then he has to keep it!!!!!!! lol! it will be a sad day in the hood when it is gone! u will have to get a evo! lol
The car had loads of interest on the day mate somebody will be along soon
was a shame you couldn't offer test rides around the track
goes really well
goes really well
does nothing seem to be selling !!!!!!!!
if anyone is more intersted i am considering selling all the 4x4 running gear
box
prop
rear beam
shafts
sump
all can be seen and heard running
all is in perfect order
pm or ring 07886481961
thanks
box
prop
rear beam
shafts
sump
thanks
Bet you wish you took that 6500 now
I cant sell me puma racing bombed out of the evo as alot of people telling me bad idea evo4.
I have two people want to buy the three door but i cant bring myself to part with it and it owes me fook all so why sell it i would only buy another probably not as nice either.
Anutternutter
Aug 21, 2015 06:07 PM
charliecosworth
Aug 19, 2015 02:00 PM
