Fuel line removal
Old Aug 8, 2008 | 06:50 PM
Rick's Avatar
Rick
Default Fuel line removal
How do u remove the plastic fuel line from the metal one on the fuel inlet side? It's dark and i can't see!
Old Aug 8, 2008 | 07:21 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
if ya thinkin of wht i think ya thinkin,ya cant!
Old Aug 8, 2008 | 07:28 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
As I said, I removed mine with a specialist tool.
A hacksaw.
Old Aug 8, 2008 | 07:41 PM
nigel b's Avatar
nigel b
2 small scredrivers holding down the tabs and pull off
Old Aug 8, 2008 | 07:45 PM
Rick's Avatar
Rick
I can't actually see any tabs as such.... I think it's the same fitting as on a fiesta fuel filter outlet. I've got a braided metal hose to connect to it instead of the plastic one, which will go straight to the filter bypassing the accumulator. This looks to be some push fitting. I take it when i get the plastic bit off, I just shove the metal pipe into the new fitting and it will snap home?
Old Aug 8, 2008 | 08:25 PM
nigel b's Avatar
nigel b
is it these type of connections?
if so put the screwdriver where the arrows are
Old Aug 8, 2008 | 09:46 PM
Rick's Avatar
Rick
Nigel - huge thanks - it is this type.
However - the white piece in your picture is no longer attached - it cracked so i forced the rest off. I take it what i should be leavering/pressing on with the screwdrivers is now exposed? i.e. what your actually pushing on isn't part of the white piece.
Rick.
Old Aug 9, 2008 | 04:27 AM
nigel b's Avatar
nigel b
it should be a metal quick release connector
as soon as it is moved down slightly it releases the pressure and can get pulled off,sometimes they are a very tight fit and are hard to pull off
Old Aug 9, 2008 | 08:53 AM
Rick's Avatar
Rick
will have a go today - appreciate your help.
Old Aug 9, 2008 | 02:32 PM
Rick's Avatar
Rick
Dremel to the rescue.... Wouldn't budge so i had to get physical. The new braided line with metal fitting snapped straight onto the fuel line, so hopefully it's sealed.
Old Aug 9, 2008 | 04:24 PM
nigel b's Avatar
nigel b
lol
at least its done now
1300gt
Sep 7, 2015 12:06 PM
muffster
13
Sep 3, 2015 09:40 PM
3doorcozmess
Aug 21, 2015 11:17 AM
RSMK4TURBO
Aug 13, 2015 08:06 AM
muffster
Aug 12, 2015 08:14 PM
