2wd --> 4wd
Thinking of converting the saph to 4wd just because the power i intend it to have will be alittle to much for 2wd.
so what would i need to convert ?
box,
prop
diff
beam
half shafts
hubs
trailing arms
anything else ?
what power are the diffs and box good for in stardard form and what is the next upgrade ?
box,
prop
diff
beam
half shafts
hubs
trailing arms
anything else ?
box,
prop
diff
beam
half shafts
hubs
trailing arms
anything else ?
box,
prop
diff
beam
half shafts
hubs
trailing arms
anything else ?
largely dependant on how you drive, i would say around 350bhp max, next stage would probably be something like a mullit box
Just sell and buy a 4bee........
Some 4wd on here have 380 odd, depends how you drive as Twells as said, a 2wd box/diff will die if you're a loon behind the wheel.......
ask JB..
I'm no expert on 4x4 mate but it is my understanding that the standard box gives up at around 400bhp with 4wd and you will need something special. Anyone got any suggestions here? Certainly in the thousands.
T5 2wd can go up to around 450 - 500 from what I've been told but I've got noises from my rebuilt one after a year of thrashing around with 450bhp - so am going to contact Marco Polo on here to sort something with Barra for me.
I know it does, but, alittle short on cash, and half the parts missing from my 2wd mean it will be staying 2wd as i cant aford to replace it
you will need all the mechanicals form the front, so :
shocks, hubs, brakes, tca's, arb, crossmember, steering rack, intermidiate steering shaft, sump, front diff (the rear diff is ok as it is), both props, gearbox, starter, engine mounts (the mounts on the crossmember and the mounts that bolt to the engine), gearbox mount
plus a big hammer to bash the tunnel (or at least a scissor jack) to open it up, and even then you may need to cut and mount the 4wd gearbox mount slots into the shell
the chassis rails can stay as they are at the front
Interesting.
why do somepeople say the front legs need modifying ?
Arnt the rear diffs different ratios, meaning i would have to use the 4x4 one otherwise killing the lsd?
can you not fit the 2wd 4pots to 4x4 hubs?
Rear diff is 0.02 out IIRC and will not hurt the VC.....Infact putting a 2wd rear diff/beam in a 4x4 is a cheap way of getting a very strong setup. So going from 2wd to 4x4 the back end will be fine...no need to touch it.
The front chassis legs have a small half circle cutout in them to clear the shafts at full suspension compression otherwise the front chaft would hit the chassis leg...simple mod probably take about 1/2 hour with right tools/equipment.
2wd 4 pots will not fit 4x4 hubs, theyre designed for different calipers....the 4x4 caliper and disk setup provides better braking force anyhow...you might be able to make up a bracket or modify calipers to fit the 4x4 hub if you tried to...not normally a mod people do though.
I have a few 4x4 bits for sale if your interested in whats left you could save some dough as I want shot so will sort you a good price
The whole front end suspension wise (bar hubs) of an xr4x4 will fit and work fine, you dont have to buy cossie stuff....think the rack might be slightly different to a cos (IIRC cossie is quick rack??? not 100% sure) but would keep costs down.
To save me typing up a huuuuuuuuuuuuuge post pm if yu want with the setup you currently have and what you want to do and I'll tell you exactly what you're going to need.
If you intend to get a bara box (speak to marco polo on here if you do
Dan
I'll also swap you the bits in exchange for your 2wd stuff if you want to keep money changing hands to a minimum, I need 2wd spares so we can work a deal maybe....pm me and we'll chat.
Dan
Dan
No they can't dojj.......why the hell would ford alter the 2wd chassis to clear the shafts if they didnt have to....and on a std car..not lowered like a lot of cossies are.
I've seen 2 converted to 4x4 cars and both had damage to shafts and chassis rails. Simple mechanics tells you it will hit if your suspension ever compresses fully.
Dan
Dan
Also are you running a 200 block bottom end? If not then your 205 block isnt ideally suited to have the added stress of the 4x4 front drive going through it...not that i've ever seen a failure personally but heard its not a good idea & at your power level might be a problem if your on a 205 block.
dan
dan
i belive there is a difference in the 2wd - 4x4 shells not quite sure exactly what it is and how hard to overcome it, but im sure ive seen it somewhere a place that make special g/box craddles for mt75-2wd shell & t5-4wd.......... dunno but im sure it would be easier to buy a 4x4
Dan
Dan
seen plenty of them done wihtout any mods to the chassis legs myself mate, so we'll have to agree to disagree on this matter
If you hit full compression on any of them cars you've seen then it will cause damage, FACT....agree with it or not I've seen it with my own eyes happen.
Dan
your short on cash and think converting a 2wd to 4wd to handle 475-500bhp will be cheaper??
my cars 2wd and my new engine is going to be kicking around 465 out iv brought a big tooth box and a quaife atb diff for the same price its going to cost you for a box for a 4be, then you have to uprate the rest. makes more sense to stick a 450+engine in a 2wd but if you have the money then go for a 4x4.Dont forget a 2wd is more fun
my cars 2wd and my new engine is going to be kicking around 465 out iv brought a big tooth box and a quaife atb diff for the same price its going to cost you for a box for a 4be, then you have to uprate the rest. makes more sense to stick a 450+engine in a 2wd but if you have the money then go for a 4x4.Dont forget a 2wd is more fun I'm not going to agree to anything I know is wrong, why would for take a 2wd chassis and only change the tunnel (for obv reasons) and the notches in the legs.....do you think they decided to spend money on modifications that were avoidable? I dont think so!
Dan
Dan
i'm not disputing the fact but of all the cars i've known that have been converted (including a lot of xr4i's, they have had no probalems with the front shafts hitting the chassis rails without the cutouts
my cars 2wd and my new engine is going to be kicking around 465 out iv brought a big tooth box and a quaife atb diff for the same price its going to cost you for a box for a 4be, then you have to uprate the rest. makes more sense to stick a 450+engine in a 2wd but if you have the money then go for a 4x4.Dont forget a 2wd is more fun but now im breaking the car insted lol
the suspension is thicker onthe struts and stiffer on the shocks as it needs to carry more weight on the springs
there are also 24 or 27 different spring rates listed by ford for the 4wd cars across the range so it's going to be easier to get new springs and shocks
ouch - yes Ryan might not agree and he was hardly pushing the car in his shunt was he? Myself 2wd is much more fun having driven quite a few of both. Getting new tyres today - sticky new Contis
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
dojj
28
Sep 11, 2015 10:00 PM
