polybushes on 2wd cossie
Old Aug 4, 2008 | 09:41 PM
b14dave's Avatar
b14dave
Default polybushes on 2wd cossie
when doing the tca bushes replacing originals with poly ones do youu have to use the original big metal washeres with the plastic bit round them, with the polybushes.
Old Aug 5, 2008 | 04:36 AM
YES, but don't worry if the plastic bit is worn away, just be sure to "dish" washers the correct way, put weight on the car before finally tightening as well if you can.
mark r
Sep 29, 2015 07:27 PM
arfurski
Sep 26, 2015 10:39 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dojj
28
Sep 11, 2015 10:00 PM
truffleshuffle
Sep 10, 2015 09:35 PM
