Engine warning light 3dr
Old Aug 3, 2008 | 03:43 AM
graeme's Avatar
graeme
Default Engine warning light 3dr
Hi guys
have just bought a 3dr and the engine light has started coming on
is there any way of i can self diagnose as the local ford dealer
hasnt even seen one of these.
Thanks in advance
Graeme
Old Aug 3, 2008 | 04:19 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Engine light?
Old Aug 3, 2008 | 06:39 AM
LHD220Turbo's Avatar
LHD220Turbo
Originally Posted by graeme
Hi guys
Thanks in advance
Graeme
didnt think there was an engine light on a 3 door, post a pic of what you mean
Old Aug 3, 2008 | 06:55 AM
graeme's Avatar
graeme
dont have a photo of the light
but its on row of lights above the clock
on the very righthand side
(at least i think it looks like an engine lol)
Thanks
Graeme
Old Aug 3, 2008 | 06:56 AM
Mark_w's Avatar
Mark_w
Hi guys
Thanks in advance
Graeme
Is it modified??? if it is then this is a common problem with older chips as when standard,the warning light comes on if the car reaches 14.7psi,which is to prevent damage on standard set up.
When modified to stage one and above it lights up at 14.7psi and most people stick a bit of black tape over it!
mark
Old Aug 3, 2008 | 07:08 AM
cossie604's Avatar
cossie604
Mine never did that above 14.7psi.....if its been mapped properly I cant see why the ecu would try and store a trouble code when its parrameters have been increase?
Yes you can do your own blink test's mate.....give me a sec ive got it saved somewhere.......
Old Aug 3, 2008 | 07:16 AM
cossie604's Avatar
cossie604
http://www.bigturbo.co.uk/main7.htm
Old Aug 3, 2008 | 07:38 AM
graeme's Avatar
graeme
Thanks for the replys fellas
the light comes on at low speed very little boost it also cuts out for a second then keep runing, it is chiped to level 2,light greens, 15 psi.
cossie604 your a legend thanks for that mate.
That will save me a real head fuck
Old Aug 3, 2008 | 07:43 AM
cossie604's Avatar
cossie604
no worries fella!
Old Aug 3, 2008 | 07:48 AM
Mark_w's Avatar
Mark_w
I just sold one of these on ebay,makes it a little easier http://cgi.ebay.co.uk/ws/eBayISAPI.d...MESO:IT&ih=017
mark
Old Aug 3, 2008 | 07:51 AM
daz1968's Avatar
daz1968
my car had light on similar situation to you, when I did the test was crank senser phasing, just had to turn the distributer a little to get it all back in line. I have ne ver heard of it coming on when running higher boost, don't even think it has a fault code for overboosting, it is a twenty odd year old ecu and is not anywhere near as complex as modern systems.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
martynhomer01
16
Aug 4, 2015 09:55 PM
