YB comp ratios
Old Aug 2, 2008 | 08:41 PM
Doby's Avatar
Doby
Default YB comp ratios
What is everyones opinion on this,with MAD using 8.4-1 on a 800+ engine what will this mean?
Is low comp going to be a thing of the past for big bhp or is it the reliable choice still?
This is not a smart arse/slag tuner postIts a genuine question as if MAD pull this off low comp will be the thing of the 80's.
Please Please see this as a genuine post,i am fed up of being called a troublemaker,i know the cynical will see it as trying to say other tuners are wankbut that couldnt be further from the truth.I have always been told by some std and higher comp is the way to go for the YB but it was equalled by the folk that said low comp is the way.
Is this the dawn of a new era?I am a fanatic ref the YB and its development.
Old Aug 2, 2008 | 08:58 PM
jacko's Avatar
jacko
if you can get away with high comp and releve some lag at the same time as ganing torque it would be rude not to lol
Old Aug 2, 2008 | 08:59 PM
Benni's Avatar
Benni
Ban[B][/B]ned
I guess different tuners will always have there own opinion and ways of doing things.
Benni.
Old Aug 2, 2008 | 09:01 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Phil,
Mark has been saying for a while now that the only thing good about the 80's was the music. low comp isnt the way forward now apprently
Old Aug 2, 2008 | 09:08 PM
Doby's Avatar
Doby
Rich i have always said higher comp was the way but was always shot down,i beleive MAD had a chat with JG because of what i said,maybe wrong i am not out to cause trouble.I know not alot but i can get advice from the pro's due to my business.
Old Aug 2, 2008 | 09:24 PM
Mark Shead's Avatar
Mark Shead
Phil
I have only had 2 conversations with people at JG and these were renting there dyno to shut up the doubters about the dyno I use, then about the 99 block a year ago nothing else,
But when you start hearing about companies going up on comp ratio it starts you thinking and then analising your data on your engines/mapping then tweaking spec's to suit,
This has been ongoing for over a few years but I have taken a carefull aproach so it has been going up over that time and more data collected,
Not anytype of spec can take a big increase in comp there are a few hidden details that make it work also,
So saying your trad T4 engine can go from 7.2-1 to over 8-1 is not always correct there are some changes that need to be made also to make it work well.
Mark
Old Aug 2, 2008 | 09:30 PM
MikeR's Avatar
MikeR
Go to bed Mark or is the little fella keeping you awake lol
Mike
Old Aug 2, 2008 | 09:31 PM
dumped's Avatar
dumped
Is it not partly engine geometry, combustion chamber design and piston speeds being reduced compared to running std rods/stroke which helps?
Cams, big turbos etc and moving the power band north all make a difference I would imagine. The big power evos are all up at these comps - do they run the same sort of pistons speeds etc?
At a guess Rod's is not std on any of these.
Old Aug 2, 2008 | 09:34 PM
jacko's Avatar
jacko
i think the length of the rods will play a big part
Old Aug 2, 2008 | 09:35 PM
Staffi's Avatar
Staffi
Mike
Mike,
He usually blames me with my PM`s.........
Old Aug 2, 2008 | 09:37 PM
MikeR's Avatar
MikeR
Then just give in and tell him to order the best turbo for your car lol,
It's about time you modded it a bit more then sold it to somebody else isnt it lol
Mark you taking care of my car, it aint moved far has it...
Mike
Old Aug 2, 2008 | 09:44 PM
Mark Shead's Avatar
Mark Shead
Mike
Not moved yet just need to be sure to move it
Mark
Old Aug 2, 2008 | 09:47 PM
MikeR's Avatar
MikeR
I am giving you plenty of time l have a bloody wedding to pay for and a Porsche to shift, plus l am in the states this winter so will be topping up your DVD collection and shopping for bits lol
Mike
Old Aug 2, 2008 | 10:02 PM
Mark Shead's Avatar
Mark Shead
Phil
The other side of the coin will be he's not actually running it that highIam sure the odd tuner would be saying this,
I may post a picture of the piston one day but its not that trick a shapeits the other bit that make most of the diff.
Mark
Old Aug 2, 2008 | 10:07 PM
jacko's Avatar
jacko
length of piston and rod can be change so tht it dont push to hard on the cylinder in its stroke due to anglu would realy like to now what hadland has done because his is loner throw he gets alot of the bad bits back
Old Aug 2, 2008 | 10:19 PM
Staffi's Avatar
Staffi
It's all in hand Mike, as for selling, i might even keep this one for a year or more.. really hooked on this old taxi for some reason..
Old Aug 2, 2008 | 10:29 PM
costina's Avatar
costina
Live long and prosper!!
Simon Norris i think uses the theory build a high power N/a engine then turbo it
He built a cossie a few years back that i had the pleasure of being in with higher comp than std went really well with over 600bhp too
With the more controllable ecus there are now and the big roller bearing turbo's which flow more helps keep the temps down hence higher comps and more ignition can be used for more power
Only if you know what your doing !!and there are only a few that do
Paul
Old Aug 2, 2008 | 10:32 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as i understand it lowering the comp ratios releaves the stresses of engine componants at a sacrifice of power and torque which can be compensated for by upping the boost pressure.
however if the engine is really well built a high compression ratio can be used and more power can be released, therefore a lower comp engine needs more boost to produce a certain power, thusly the higher comp engine has more power potential and more torque than the lower comp engine.
i used to run a high comp engine on a tt setup and at 10psi it was far quicker than 13psi on a low comp erst engine.
it's mainly cost effectiveness that dictates which method gets used.
Old Aug 2, 2008 | 10:37 PM
puddy's Avatar
puddy
Originally Posted by Mark Shead
Phil
Mark
Is it the thickness of the piston crown,or lack of it ?
puddy
Old Aug 2, 2008 | 11:13 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
thickness and construction of the piston crown makes a massive contribution to the running of the engine. the better it can disipate the heat the more advance and power can be obtained.
Old Aug 3, 2008 | 12:36 AM
markk's Avatar
markk
how the worms have turned lol
Old Aug 3, 2008 | 08:42 AM
StephTell's Avatar
StephTell
I seem to recall Karl doing a few 8:1 engines with a T4 on it rather than the ussual 7.2:1 or 7.6:1?
Sounded like a nice package as well.
Old Aug 3, 2008 | 09:18 AM
Doby's Avatar
Doby
Yes karl did a T4 conversion on 8-1,i beleive Jim Green had it done?
Sorry mark if it sounded like i was involved with your higher comp decisions,i remember chatting to you about my 7.9-1 and GT35 and saying that JG says no probs so assumed you spoke to him,but as you say you saw others going up the ratio and figured it was the way and you now proving it!
Old Aug 3, 2008 | 09:21 AM
StephTell's Avatar
StephTell
My rallycar was high-comp (although I really can't remember what) and ran 1.9 bar all day long but with restrictor.
Mind you, I loved it as it was soooo responsive and mentally fast up to 100 MPH!
Old Aug 3, 2008 | 09:35 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
err, race fuel, no?
on race gas youd be daft to run in the 7s, no need.
Old Aug 3, 2008 | 09:38 AM
Doby's Avatar
Doby
Originally Posted by Stavros
err, race fuel, no?
it will still be running 700+ on pump mate.
Old Aug 3, 2008 | 09:41 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
how do we know, its not done it yet
until there YBs running as good a powerband or better, on pump gas, and with the same long term reliability (ie long top speed runs etc with no issue), i dont see how anyone can claim its the future and high comp is the way forwards for 250+bhp per litre engines.
Old Aug 3, 2008 | 09:44 AM
Doby's Avatar
Doby
going from the previous session mate on 7.9-1
I agree reliability is the key but as mark says its been well thought out to provide that.
Old Aug 3, 2008 | 09:47 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
mark is a top tuner, his cars are proven to be the bollocks, but until its proven good in the long term i wouldnt even take gods word for anything.
last engine didnt even make it off the dyno.
Old Aug 3, 2008 | 10:12 AM
Doby's Avatar
Doby
Fair point.
BUT please be aware if God did give his word to you i would be seeking medical advice.
Old Aug 3, 2008 | 10:30 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Old Aug 3, 2008 | 10:33 AM
markk's Avatar
markk
ive been running plus 250hp in the 9's for 10 years on pump fuel, like ive been telling you for years pal and thats flat out everytime its used, not going to the shops or cruising down the local strip.
GARETH T's Avatar
GARETH T
we can't sum up the whole of an engine with one number (the compression ratio) so why are people trying to!
Old Aug 3, 2008 | 10:39 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Originally Posted by MadRod
It made 727bhp on pump Stavros, why always be so negative all the time just like your ' bloody' magazine, just cos it aint Reyland dont mean it cant happen.
what you on about rod?
whats the magazine or reyland got to do with me?
nothing thats what. and negative and proven in long term are two different things.
i never said it cant happen, might wanna read what i said.
and speaking of that...
I said 250+bhp per litre mate...
Old Aug 3, 2008 | 10:46 AM
markk's Avatar
markk
and i did say plus 250 as well, did i mention 1/2/3/4 litres ?
but i didnt read it correctly !!
Old Aug 3, 2008 | 10:47 AM
dumped's Avatar
dumped
Good words
Old Aug 3, 2008 | 12:08 PM
Mark Shead's Avatar
Mark Shead
Time will tell how reliable, The issuse on the dyno last time was head gasket hopefully the change will fix this,
All my engines have been going up on comp for the last couple of years and these have proved very reliable so Rods engine is not to much of a risk on the reliablity side,
We know why the gasket failed and have made other changes also based on what happend,
I have another 2 engines on the go in this spec so Rods will not be the only proving the reliablity at this level.
Mark
Old Aug 3, 2008 | 12:28 PM
oohogwash1's Avatar
oohogwash1
Here is another data point for you guys.
As you know high comp concept is not new, I chatted to the head engine man for Dick Johnson with his dominating group A sierras.
(Actually he still has the original engine lab they used, with all the cossy bits which is neat)
He said that they felt high compression was the way to go way back then but they never had enough time to research it fully, they worked with the Group A guidelines, and found extra power by other means which was interesting but off topic for this thread.
He went on to say that since that time (sierra group A) he did go down that path and works with high comp engines constantly and talked of the low comp spec as being very old school and something they left behind a long time ago. A lot of WRC work goes his way, which guys mentioned on this thread is high comp work.
His team did a lot of stuff that set them apart from sierras all over the world, I respect his opinion.
Old Aug 3, 2008 | 04:14 PM
Doby's Avatar
Doby
very interesting
Old Aug 10, 2008 | 08:05 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Rod you are one sad man Ha ha ...I know you edited it out but was quoted before it was lost!!!!!!!!
