how do you do the timing on small turbo esc
Old Jul 30, 2008 | 04:06 PM
B15Risk's Avatar
B15Risk
Default how do you do the timing on small turbo esc
hi is there any one out there who knows how to time up a small turbo escort cosworth i need help cheers
Old Jul 31, 2008 | 08:58 PM
B15Risk's Avatar
B15Risk
an anyone help please
Old Aug 1, 2008 | 10:25 AM
sailorbob's Avatar
sailorbob
Cam or ignition timing?
Old Aug 1, 2008 | 02:44 PM
B15Risk's Avatar
B15Risk
ignition please as it dont have a dizzy cap
Old Aug 1, 2008 | 02:56 PM
sailorbob's Avatar
sailorbob
The ignition timing is controlled by the ecu and EDIS unit, there is no adjustment unless you chip the ecu.
Old Aug 1, 2008 | 03:08 PM
B15Risk's Avatar
B15Risk
is there a special way to have the pulley is there any markings any where so i can put it in the right place cheers
Old Aug 1, 2008 | 03:12 PM
sailorbob's Avatar
sailorbob
Do you mean how to position the CMP sensor?
Old Aug 1, 2008 | 03:27 PM
B15Risk's Avatar
B15Risk
yeah that the one
Old Aug 1, 2008 | 03:36 PM
sailorbob's Avatar
sailorbob
When viewing the sighting 'glass' of the CMP sensor there are 3 marks; a short line (on the left), a long line (almost the full height of the glass in the middle) and an arrow pointing clockwise (on the right). You will also see a vane through the glass when you rotate the sensor's drive gear. You need to rotate the vane clockwise so that the back edge of it lines up with the long mark.
The long line is shown in red and the vane in green.
Old Aug 1, 2008 | 03:41 PM
B15Risk's Avatar
B15Risk
thank you
steerfromdarear
28
Jan 29, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
IAN RS2k
Aug 18, 2015 07:51 PM
marky_g
Aug 3, 2015 04:45 PM
