Zetec Throttle Bodies
Old Jul 30, 2008 | 03:55 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
Default Zetec Throttle Bodies
i was thinking of fitting gsxr750 throttle bodies to a zetec but have never done it before so i was after some help
what manifold was used?
what management?
what fuel rail/injectors do you use?
any info will help
thanks
Old Jul 30, 2008 | 03:58 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
well it all depends on how much you want to spend? i no you need a spacing kit as they are to clost 2gever for the zetec inlet ports? megasquirt is an option for managment fuel rail will have to be made and the injectors all depends on wot engine you are useing?
Old Jul 30, 2008 | 04:02 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
what about something like this?
http://cgi.ebay.co.uk/throttle-bodie...3286.m14.l1318
it says there suited for a 2.0 but isnt that down to the management you use?
Old Jul 30, 2008 | 05:40 PM
Pob's Avatar
Pob
Its down to budget I think, if your going for injection. I'm pretty sure the cheapest aftermarket ecu is megasquirt. My mates runing omex on his mk2 zetec.
I'm a skint so i've went the carb route.
IF you can find some one breaking an st170, that way you'll have the injectors-then sticks some bodies on the end.
http://www.mez.co.uk/ms10.html
Old Jul 31, 2008 | 03:12 PM
clarke5700's Avatar
clarke5700
could work i gess
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
