RST won't fire up
I leave my RST unused for a few days (say a week) and it won't fire up. After trying, leave it for a couple of hours and it will fire up straight away. However if I do turn it on every couple of days, no problems at all.
Checked the current, spark, compression, fuel pressure... everything is fine. Dizzy & coil are new. What the hell is the prob?!
Sounds like maybe fuel pressure isnt holding in the system?
How about turn ignition on and off a few times before starting, how does it go then?
If it works ok then, try the Fuel accumulator, and makesure their is a one way valve (or a working one way valve) on the fuel pump!
