afr guages
Old Jul 27, 2008 | 09:21 AM
c9sse's Avatar
c9sse
Default afr guages
i am looking in to fitting one of these at the moment (stack)but what i dont understand is do i have to fit an extra boss in my exhaust or will this replace the lambda sensor i have.
the car is a small turbo escort, i have had problems with it being lean in the past without knowing so i have replaced air meter and having the pump and wiring checked but will and faulty lambda cause this,plus the car has its cat removed.cheers darren
Old Jul 29, 2008 | 05:50 AM
KSA-Cossie's Avatar
KSA-Cossie
Yes,you need to fit an extra boss m8.
Old Jul 29, 2008 | 05:56 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You don't have to run two sensors if the wideband also outputs a simulated narrow-band output.
Old Jul 29, 2008 | 04:58 PM
c9sse's Avatar
c9sse
will be honest mate i dont know about wideband outputs and that,its just that i ran my car not knowing it was very lean so i have see this gauge(stack) on rainbirds site and thought it was a very good investment that it dont happen again.
cheers darren
15
Oct 7, 2015 03:43 PM
Chas
Oct 5, 2015 07:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
Marino
Sep 12, 2015 11:10 AM
