rs500 thermostat
The posh are up!!!
i heard that a rs500 thermostat will make a series 2 cool better? mine has pace front mounted cooler and on the run it is fine but, going around town it gets very hot even with the 2 fans on
None of the thermostats will make it cooler better, just lower the temp that the fan starts running.
It could just be that your thermostat is old and needs replacing with a new unit that opens at the correct temp.
I think (not 100% which model, think it's just any Cosworth item) these open at 82 degrees, but any Cos buff should know the answer for you.
PassionFords Creator
The Enigma
Sep 29, 2015 10:31 AM
