N/A Zetec Into Mk3 Escort
Old Jul 25, 2008 | 07:33 PM
Cozziekid's Avatar
Cozziekid
Default N/A Zetec Into Mk3 Escort
How easy (or hard) is it to wire in the engine loom for a zetec into a Mk3 loom?
What parts will i need (from zetec donor car) and where and what do i need to connect the wires to, or if anyone has a wiring diagram or detailed instructions that would be great thanks.
Old Jul 26, 2008 | 04:33 PM
fonfe's Avatar
fonfe
pre pats 1.8 loom is only 5 wires to hook up, 2 switched lives, permanant live, earth strap, rev counter.
when you strip the donor car you will see that you have an engine harness that then just plugs into the ecu harness, you will only need the bit of the loom that hooks up to the edis module, engine harness and then back to the ecu.
Old Jul 29, 2008 | 08:15 PM
Cozziekid's Avatar
Cozziekid
Ok thanks mate. What year did pats system come in?
Old Jul 29, 2008 | 08:48 PM
rst in breaking's Avatar
rst in breaking
i think if you get a 2.0 mondeo, early one, you can get ecu type "deep, desk or dewy" which is non pats
Old Jul 30, 2008 | 08:02 AM
Cozziekid's Avatar
Cozziekid
Thanks mate, helps when i know what kind im looking for lol
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
gingerturbo
Aug 18, 2015 07:58 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
